R56 Best aftermarket control rod/arms?
So I noticed a clunking noise coming from my front right suspension recently when I would hit large bumps. After doing some research it sounds like my control rods are either bad, or the bushings are bad. So I figured I may as well replace them all.
Any recommendations on brands/models? I also want to switch to poly bushings too since the consensus is they last longer and perform better.
I installed PowerFlex control arm bushings recently and with the 3 part bushing was not too difficult to do. I replaced the inner and outer ball joints, tie rod ends and sway bar links on our 2002. I ordered everything from pelicanparts.com. You can also check ecstuning.com. Both have good pricing and selection and ECS is very active on the forums.
Yes, I got an alignment yesterday shortly after commenting and it helped tremendously. Only my right rear tire was out of spec they said. Take it to a dealer for an alignment. I was told by Firestone in the past that they don't have the machine with weights which is what BMW has? Anyways, my dealer charged $97 with tax and a hour and a half wait later, its driving much better over bumps. Definitely buying the power flex bushings in the spring.
ej
Nov 17, 2015 09:21 PM
Sep 4, 2015 02:34 PM
