R56 Engine Bay Mystery Valves?
Old Jul 25, 2014 | 09:26 AM
Elemeno64's Avatar
Elemeno64
What are these two valve cap things on my 2007 MCS? I have searched for ages but can't figure out what they are. If you unscrew the black caps, there appears to be some sort of valve inside the tube.
I traced a low RPM rattling to the #1 rubbing on the underside of my hood. It is just freely waving around - is there supposed to be some sort of tether or bracket that holds it in place? It has actually worn off a section of the paint where it has been rubbing.
Thanks.
Alan
Old Jul 25, 2014 | 10:02 AM
Those are the high and low port for charging for the A/C system. Dont, push in the valve they are pressurized with R134a gas and used as part of the A/C ssystem. Just make sure there are caps on there and on tight.
#8 ( #2 in your diagram)
http://www.ecstuning.com/Search/SiteSearch/64538387438/ES2674433/
# 9 ( #1 in your diagram )
http://www.ecstuning.com/Search/SiteSearch/64538387437/ES2675007/
There are the plastic mounts that hold these in place, they sometimes break.
http://www.ecstuning.com/Search/SiteSearch/64502755879/
# 11, ( in the digram #15 does not exists , but #11 is the whole unit )
http://www.ecstuning.com/Search/SiteSearch/17122757196/
Old Jul 25, 2014 | 11:13 AM
Elemeno64's Avatar
Elemeno64
Those are the high and low port for charging for the A/C system...
Wow! Thanks for the fantastic, detailed reply. I don't post very much but I read quite a bit and I love this place - such a wealth of knowledge.
Alan
Old Jul 25, 2014 | 11:34 AM
Yep , you are welcome , those lines just snap into location on those holders, they are very tight when clipped in.
Old Jul 25, 2014 | 12:03 PM
rckrzy1's Avatar
rckrzy1
my low side #1 rubs under my hood and it's in the holder but I'd have to bend the line to get it down, I'll let MINI try that next service.
Old Jul 28, 2014 | 05:46 AM
Its might not be clicked in right, there is a little notch on the metal line where the plastic snaps around. They sometimes are not snapped in all the way, or to low on the neck. Check it, might be an easy fix.
Kimolaoha
Jul 5, 2023 01:04 PM
blackie
Jan 18, 2017 09:57 PM
blackie
Jan 18, 2017 09:56 PM
makg
Aug 21, 2015 02:49 AM
chicohuahua
22
Aug 20, 2015 11:17 AM
