R56 Is this knocking, mis-firing, or oil fouling?
Old Sep 8, 2014 | 07:00 PM
  #26
cerenkov's Avatar
cerenkov
Originally Posted by bcman
Okay, here's another question about knocking: Aren't these cars supposed to have a knock sensor that retards the timing? I remember reading about that on my mom's '94 Volvo that took premium. I figured by now that would just be standard equipment on all cars. I accidentally filled up with 87 octane last week, and now the car knocks every time I drive home. It's imossible to drive in a manner that avoids it entirely. Surely something must be wrong? Could my knock sensor be failing?
The knock sensors in these cars are suppose to be very good but they can only do so much. I would put in the highest grade premium that is offered in your area. Even if you can only pump in a few gallons it will help raise the octane.
Old Sep 8, 2014 | 08:02 PM
  #27
Systemlord's Avatar
Systemlord
A knock or pre-ignition happens when the fuel/air ignite prematurely (to early) cause a ping (called knock) like sound, the lower the octane the faster the fuel burns. The higher the octane rating the slower it burns, the 87 octane doesn't have enough explosive energy to force the piston downward. High cylinder temperatures can also cause your engine to knock, solution is to find a way to lower your intake temperatures, a larger intercooler and or meth injection can suppress knocking. The knock sensor should still prevent knocking when using low octane, could be a bad batch of fuel.
Old Sep 9, 2014 | 08:42 AM
  #28
two250's Avatar
two250
I bet it backs timing down when it knocks, but it's going to put it back where it's supposed to be after a while. Then it will knock again and pull timing again. One knock isn't going to cause it to pull timing for the rest of the cars life.
Old Oct 1, 2014 | 03:50 PM
  #29
actasci's Avatar
actasci
i posted at comment section on youtube too, same problem. some people think that i'm an idiot for using this car after sh.tload of failure and service bill, i know i am, but i really want to believe if i solve this, everything is gonna be fine, really. i mean, engine is smooth as silk, power delivery is smooth, turbo is whooshing like it's new; but if i want some power at low rpms going uphill, this happens.
it's not about premium gas nor intake temps, i changed tensioner (it's seems less common after changing tensioner though), injectors, sparks and hpfp. and even though i'm driving like a grandma, without any leaks, i'm burning more than 1 quart of oil per 1k miles.
it's probably because of the carbon deposits. if you can get it cleaned, i say do it.
alex87f
Mar 25, 2017 03:46 PM
ericbryant24
Aug 29, 2015 01:55 PM
Marktheman
Aug 23, 2015 11:45 AM
wind715
Aug 11, 2015 07:56 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
