R56 Need help with brake/clutch fluid transfusion (w/ power bleeder)
Old Apr 1, 2014 | 05:24 AM
bit_bucket's Avatar
bit_bucket
I have replaced all brakes and rotors on my 09 MCS and it's time to run new dot4 through everything and flush out the old. I have a motive black label pressure bleeder and know how to do the brakes. Where I am hung up is the clutch slave. Here are the steps I believe are right.
1) Make sure reservoir is well past full mark with fresh fluid and also have plenty of fluid in the bleeder.
2) Preasurize bleeder to 10psi
3) compress piston on slave using tool. Make sure it is straight in and not crooked.
4) Attach clear hose to bleeder nipple
5) Open bleeder valve on slave and let fluid come through until it looks clean
6) Close bleeder
7) Remove compression tool
8) Actuate clutch pedal a bit to make sure all is well
Am I missing anything or is my procedure flawed?
Old Apr 2, 2014 | 05:49 AM
abonn
Agree with your procedure
I have done this bleeding procedure at 2-year intervals since purchase on my 2007 in the way you described it. If the pedal is solid after you finish, you are all set.
Old Apr 2, 2014 | 06:17 AM
v10climber's Avatar
v10climber
Looks good to me. Just make sure you don't let the reservoir go dry.
Old Apr 2, 2014 | 06:23 AM
Helix13mini's Avatar
Helix13mini
If it goes that smoothly for you, consider yourself a master. Prepare to repeat the steps several times, especially the first time you do this. Allow for much time and patience.
Old May 8, 2014 | 10:45 PM
Jlobb2's Avatar
Jlobb2
What tool did you use to compress the slave, and where did you get it? I'm about to flush my brakes and I'm wondering if I should bother with the clutch slave.
Old May 9, 2014 | 08:31 PM
bit_bucket's Avatar
bit_bucket
I actually did not bleed the clutch. The slave was markedly different looking than the pictures I saw. Didn't was to mess something up. As far as the flush for the brakes, it went down without a hitch using the power bleeder. I just bled each line until the fluid went a lot clearer. Only had to do single flush and the brakes feel great. Have put 1500+ miles on them now and they are solid. I am finishing up a condenser repair tomorrow (dang deer strike) and will take pictures of the clutch slave on my car to see if anyone can make heads or tails of that.
Old Nov 30, 2014 | 10:22 AM
automan21's Avatar
automan21
Any word on that pic?
PelicanParts.com
Tires, Wheels & Brakes
Sep 9, 2015 01:37 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
ou812_tugger
Sep 5, 2015 03:24 PM
PelicanParts.com
Accessory Products
Sep 3, 2015 08:54 AM
Ntety
Sep 2, 2015 08:39 PM
