R56 Questions about Aftermarket Downpipe
Old Mar 19, 2014 | 07:55 PM
  #26
elsenordave's Avatar
elsenordave
I had that issue but my stage 2 tune seemed to resolve it. The spacer seems to exacerbates it. I had a bigdaddies on for a while but ended up taking it off...ran better.
Old Mar 19, 2014 | 08:28 PM
  #27
gerardt20's Avatar
gerardt20
can the access port stop the light from ever appearing?
Old Mar 19, 2014 | 10:47 PM
  #28
elsenordave
I believe so but don't quote me. I know battle tune does.
Old Apr 28, 2014 | 09:29 PM
  #29
wzabrouski's Avatar
wzabrouski
Originally Posted by zcast
It is basically a spacer for your O2 sensor on your exhaust. Spacing it further away allows it to pick up "cleaner" air. Per the description: The factory ECU is comparing the readings from a pair of oxygen sensors to measure the effectiveness of the cat. When a high-flow cat is used the exhaust gases are able to pass by the cat at a much faster rate, disrupting the readings. The o2 sensor spacer retracts the second oxygen sensor from the direct flow of gases, restoring the balance that the ECU requires when using a high-flow cat. I am going this route first before I have my tune clear it for me. Reason being is that a cleared CEL from a tune doesn't clear the error from reading codes on the car, and it won't pass emissions. Here in Nevada I believe it is 2 faults = fail. So instead of swapping DPs every year, I will use the spacer and tweak it until it tricks the sensor to reading clean air (hopefully....it's never a sure thing with these things, but have been very successful with VW/Audi with catless DPs). http://www.etektuning.com/42-draft-o2-sensor-spacer/
Did you have any luck with this? My 2011 with the akrapovic dp has the P0420 code stored and it is time for my annual inspection. I have the delete r to block the code but the P420 is stored as a permanent code and is preventing the catalyst and evap readiness sensors from being ready.
ltjpunk7
Sep 6, 2015 07:32 AM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
Aug 21, 2015 11:25 AM
Colt45Magnus
Aug 13, 2015 11:18 AM
