R56 Sport Button
Old Jan 25, 2014 | 02:32 PM
  #26
HorseWithNoName's Avatar
HorseWithNoName
It would be nice to have multiple steering and throttle response setting in the setup menu options, along with auto on sport mode...
Old Jan 25, 2014 | 03:00 PM
  #27
nine5raptor's Avatar
nine5raptor
Agreed!
Sent from my XT926 using NAMotoring
Old Jan 25, 2014 | 04:17 PM
  #28
cambo's Avatar
cambo
Originally Posted by richardsperry
My 2010 MCS is almost undrivable without the sport mode. I practally stall it pulling away from a stop.
So, when it was new, I installed the FES auto sport module. Problem solved.
way's diverter valve solved that 1st and 2nd gear lag for me
Old Jan 25, 2014 | 04:56 PM
  #29
KeyPlayaJim's Avatar
KeyPlayaJim
Sport mode all the time except for slippery conditions -- like the ice that's on the roads right now!
Via iPhone using NAMotoring
Old Jan 25, 2014 | 06:05 PM
  #30
danjreed's Avatar
danjreed
Can you explain/detail this?
I drive w/Sport mode in part because I hate the 1st gear pull away..
(I also run it because it keeps the car cooler..)
Oh, and I like the pop.
And the heavy steering..
Ok, I just drive with it on all the time. Same thing with Traction mode.
Old Jan 25, 2014 | 06:17 PM
  #31
nine5raptor
I can totally understand the pop and running cooler. Mine doesn't do that however. :'(
Old Jan 26, 2014 | 08:52 AM
  #32
cambo's Avatar
cambo
Unfortunately I'm too dumb to explain how it works...something about a spring and another thingy ma jiggy. Here's the description from his site:
"This valve is a direct replacement for the stock blow off valve that recirculates the boost. It has a stronger spring and actuator allowing it to open and close faster than the standard valve. This will allow you to build boost faster and on deceleration dump it faster. This will help eliminate turbo surge. For the price you can't go wrong."
and then there are a ton of reviews, this is the most heavily reviewed product on his page that I've come across. nothing but positives:
http://www.waymotorworks.com/wmw-per...off-valve.html
Old Jan 26, 2014 | 12:20 PM
  #33
Angelbethany's Avatar
Angelbethany
Does anyone find that sport mode impacts your gas mileage?
Old Jan 26, 2014 | 01:04 PM
  #34
danjreed's Avatar
danjreed
Sweet! Thanks! Found my next Mod!
Old Jan 26, 2014 | 04:26 PM
  #35
nine5raptor
Dan, check with way first. They recommend the forge valves for N18s.
Old Jan 26, 2014 | 08:26 PM
  #36
mini coop's Avatar
mini coop
So, explain how sport mode makes a base Mini perform better? Turbo accessories can't help.
Old Jan 26, 2014 | 08:46 PM
  #37
CooperJCW's Avatar
CooperJCW
With the auto transmission it mostly just changes the shift points and steering. Not sure what it does with the manual justa?
Old Jan 27, 2014 | 04:17 AM
  #38
nine5raptor
Same as with the turbo. Changes steering and throttle mapping.
Old Jan 30, 2014 | 10:55 AM
  #39
cWade's Avatar
cWade
Is there a difference in pressing the sport button and moving the shift lever to sport in an automatic?
Thank You
Old Jan 30, 2014 | 05:52 PM
  #40
Ishihara's Avatar
Ishihara
OK, this was me for the first month until I finally caught up in the forums here and gave it a try. Worked like a champ, save the odd high rev starts... then I got the JCW engine kit from Santa... the MA said that if I used sport before, to keep on using it... but to be honest, the kit completely changed the nature of this car, and I haven't used it since...
anyone use it on upgraded/modded cars? curious if the changes still feels the same...
Old Jan 30, 2014 | 07:05 PM
  #41
thebutternutter's Avatar
thebutternutter
I have been curious about this as well. I am guessing the exhaust pop is achieved by firing an injector on the exhaust stroke. Can anyone confirm? Measurable reduction in mileage due to this when running Autosport module or simply because you're mashing the go pedal all the time?
I've been driving standard shift vehicles my entire driving life (16 years) and have never had such a difficult time starting/shifting smoothly than with a MINI.
Old Jan 30, 2014 | 07:18 PM
  #42
Tall_dude's Avatar
Tall_dude
I love sport mode for ripping around town, but keep it shut off for winter driving. I don't need a hotter throttle response when I'm sliding around in the snow. Also, I usually shut it off for freeway driving. It seems kinda pointless when you're cruising at a steady 75 mph...
Old Jan 30, 2014 | 11:46 PM
  #43
KeyPlayaJim
Funny you should say that! I learned to drive on a manual transmission (a full-size 1970 Jeep pickup -- definitely not mini!) and have been driving mostly manuals since 1971. When I bought my MCS, it had been 10 years since my last manual, and I felt almost as if I was learning for the first time. Maybe the clutch takeup is more abrupt than I was used to, but it took me a few weeks to get my finesse back.
Old Jan 31, 2014 | 04:15 AM
  #44
spiney's Avatar
spiney
Thank You
As far as I know the Sport button on an auto affects steering, throttle mapping and transmission shift points. Putting the shift lever into Sport only affects the transmission.
Old Feb 6, 2014 | 11:12 AM
  #45
Zephyr1's Avatar
Zephyr1
So from another thread I gleaned that Sport mode also lowers the engine temperature set point, at least for the 2013 N18 engine on the R56. In Sport mode, the set point is lower (cooler engine). I'm testing right now, but as I almost always drive in Sport mode, that might explain why my engine temps are always on the low side (under 90C most of the time).
Old Feb 6, 2014 | 11:28 AM
  #46
cerenkov's Avatar
cerenkov
For my 2013 MCS:
SPORT OFF --> 220F coolant temp
SPORT ON --> 175F coolant temp
Old Feb 6, 2014 | 01:29 PM
  #47
Zephyr1's Avatar
Zephyr1
Originally Posted by cerenkov
For my 2013 MCS:
Interesting, thanks for posting! Any idea why?
Old Feb 6, 2014 | 04:57 PM
  #48
nine5raptor
Multistage thermostat. Also will open the '185' valve when you are driving hard and on max AC.
Sound correct, though I usually see 185F and 227F
Old Feb 6, 2014 | 05:22 PM
  #49
cerenkov's Avatar
cerenkov
Is there any harm in running all the time at the lower temperature? If it's beneficial then why not have it run at that temperature all the time.
Old Feb 6, 2014 | 05:24 PM
  #50
nine5raptor
Fuel efficiency. You should get better mileage at the higher temp.
Lower temps can give you a little better knock protection.
