R56 Does differential go straight thru - can't remove axle
Old Dec 6, 2013 | 08:28 AM
srponies's Avatar
srponies
I am trying to remove the drivers CV axle on an '07 base automatic. It does not want to come out... even with prybars and a slidehammer/puller.
Am I missing something... it does just pull out, correct?
I already removed the passenger side axle and extension from the trans. I am wondering if the differential goes straight thru (no center pin), and if I can tap on the LH axle thru the RH output shaft hole.
Hopefully that makes sense.
Any ideas please let me know.
Steve H.
Old Dec 6, 2013 | 01:09 PM
srponies's Avatar
srponies
I ended up just removing the inner boot clamp and pulling the axle/joint from the tulip.
Steve
wkp1219
Nov 13, 2015 07:52 AM
maestro39
Oct 27, 2015 02:38 PM
LordOfTheFlies
Oct 19, 2015 05:02 PM
greekzilla
Aug 23, 2015 03:44 PM
