R56 brake pad sensor questions
Old Nov 2, 2013 | 04:48 PM
Gabe3's Avatar
Gabe3
hi, my brake pad sensor light came on and control check message. I believe its my rear because when I go into check info and into reset services when I scroll through the services, like oil and so on I see that the rear brake icon is red and show like -7 miles. my front brake icon is yellow and does not have a negative miles. I reset them both but the rear one did not change and still shows -7. light and check control msg is still there. so I'm guessing the sensor is worn through on the rear. can I get to the rear wheel sensor without taking the wheel off and splice the ends together to bypass it? I looked at my pads just with a flashlight from the outside and they look ok. I'm not sure how the sensor went on. it looks like I have plenty of life left. perhaps the side of the pad I cant see is worn more where the sensor is?
Old Nov 2, 2013 | 05:29 PM
AZdsrt's Avatar
AZdsrt
How many miles on the mini? While the outside pad looks ok, the inside pad might not..
Old Nov 2, 2013 | 08:03 PM
Gabe3's Avatar
Gabe3
opps I forgot about the inside pad. guess I'll have to take the wheel off tomorrow. is the sensor connected to the inside pad? I guess mini assumes they would wear evenly. 59k miles, I bought it a few months ago at 57k.
Old Nov 2, 2013 | 09:47 PM
papatom360's Avatar
papatom360
If you do need new sensors check out OEM Bimmer Parts. They were the cheapest that I could find the brake sensors. I did mine about 2 weeks ago and had no problems. You will need to remove the inner wheel cover at the bottom for the front. Shipping is really fast!
http://www.oembimmerparts.com/category_s/2077.htm
Old Nov 3, 2013 | 05:16 AM
jcauseyfd's Avatar
jcauseyfd
If you tripped the sensor, you will not be able to reset it without installing a new sensor. With the new sensor you can try the splice trick to prevent future cases of it being tripped.
Old Nov 3, 2013 | 05:27 AM
Capt_bj's Avatar
Capt_bj
you can splice a worn sensor - you are cutting off the end anyway. Have done it for myself and several others. Once you tie the ends together the car sees a new/unused sensor.
a sensor 'trips' when the end gets worn down so far as to break a wire loop in the end. Look carefully at the below pic' and you can see the two shiney spots that are the wire ends remaining. Pic above is a GEN2 sensor dissected. The face seen below is facing down in the pic above.
W0TM8
Dec 19, 2019 07:50 AM
bjcarter2
Aug 31, 2015 04:03 PM
penguinhomey
Aug 17, 2015 01:33 PM
