R56 Best oil to use for 2013 cooper S-N18
Old Sep 26, 2016 | 07:34 AM
  #51
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
When its a known fact that 90% of all engine wear is attributed to start up when engine is cold, I fail to see the reason why anyone especially with a brand new engine, would opt for a thicker viscosity.....regardless of your primary geographical driving location.
Old Sep 27, 2016 | 03:25 PM
  #52
cristo's Avatar
cristo
Alliance Member
Sorry, I was looking at the amsoil site, and I thought they were
referencing MINI's recommendations about the viscosities.
http://www.amsoil.com/lookup/auto-an...rbo/us-volume/
Old Jul 21, 2017 | 12:15 PM
  #53
eRock's Avatar
eRock
+1 on the Mobil 1 0w40 Euro Formula at 5k intervals. $22/5qt. at Walmart!
Old Jul 24, 2017 | 09:02 PM
  #54
sselvia's Avatar
sselvia
I knew there would be an oil thread.....
So, the spec is 4.5 liters, or 4.75 qts ( I believe). Do you guys just put in 5 qts or should I be more accurate? I guess 1/4 quart is quite a bit really.
BTW.....I've used T6 rotella in my Goldwing for 10+ years. It's always seemed to work well. But it's apples n oranges to the Mini and the turbo I know. It was always pretty dark looking at the 5K change interval....which don't don't tell the whole story really IMO. But I don't know about it for the S?
Old Jul 25, 2017 | 09:49 AM
  #55
silkcut's Avatar
silkcut
I've used Mini Oil in both of Mini's since day one. The 2009 is an N14, R56S, and the 2013 is an N18 R56JCW. Oil gets changes at ~5K mile frequency. I use the OEM filters. Total mileage for the three Mini's I've owned is ~ 300K. ( First Mini was totaled with 80 K on the odometer. The '09 has 145K, and the JCW has about 70K.)
I generally put in just over 4 1/2 quarts and start the engine up. I'll let it idle while I do other stuff until it comes up to temp. Shut it down, let it cool off and check the oil level, and fill as necessary.
Mini/BMW used to state to check the engine oil level 5 minutes after shutdown, which is a little odd to me. If they can come up with an acceptable level after 5 minutes, it isn't difficult to come up with the level when the engine is cold. I check mine cold.
BMW/Mini used to spec 5w-30, but now it's 0w-30.
There are a lot of oil threads.
Old Jul 25, 2017 | 10:00 AM
  #56
Qik420's Avatar
Qik420
I'm a fan of the 5k oil change as well (because MINI's/Euro cars are temperamental). I use Amsoil Euro 5w30, but really any full synthetic at any of the recommended weights in your owners manual will be fine taking into account the temp/time of year you'll be heading in too.
Old Jul 25, 2017 | 02:33 PM
  #57
sselvia's Avatar
sselvia
Yes, I'm also a fan of the cold oil level check. There's never going to be more in it than at that time seems to me! I giggle at all these mysterious spins mfgr's put on a basic process that's been going on since the Model A. It's either full or it ain't....flame suit on now!
I will for sure use the 5K increment and probably 5-30...but likely not Mini or Castrol. Probably Mobil or Liqui Lube or whatever that is. Amsoil is also a candidate. I do appreciate a good "steady as she goes" approach and it's tried and trued results as mentioned. I do things the same way once established with all my vehicles. Another reason the Rotella will probably get a try at some point as it's served me well in the past and it rated for turbos.
Old Jul 25, 2017 | 06:11 PM
  #58
AZdsrt's Avatar
AZdsrt
...So, the spec is 4.5 liters, or 4.75 qts ( I believe). Do you guys just put in 5 qts or should I be more accurate? I guess 1/4 quart is quite a bit really...
I get mine changed at the dealer, they put 5 qts in there. Hasn't been a problem..
Old Jul 26, 2017 | 04:40 AM
  #59
Qik420's Avatar
Qik420
Capacity is 4.4 qts. though I don't see filling .6 over being an issue, I stick to what I know. If capacity is 4.4, I put in 4.4.
Old Jul 26, 2017 | 04:41 AM
  #60
Qik420's Avatar
Qik420
Also, I think it could be that the dealers started pouring in 5qts due to these cars using a little oil between changes.
Old Jul 26, 2017 | 05:29 AM
  #61
-=gRaY rAvEn=-
Moderator
Did you actually see them pour 5 quarts into the filler neck of the valve cover, OR did you get BILLED for 5.
Many shops lack the ability to bill out .6 qts quantities therefore "round up" that figure.
Old Jul 26, 2017 | 05:32 AM
  #62
-=gRaY rAvEn=-
Moderator
If you purchased a Craven Speed dip stick, you could read your oil level at any temp.....worth the $80 dollars IMO, and if you sell or trade your MINI, put the factory one back in and sell it in the marketplace. Bet you'd end up getting 60 dollars for used one shipped.
Old Jul 26, 2017 | 05:33 AM
  #63
-=gRaY rAvEn=-
Moderator
Should NEVER overfill the crankcase of any engine, including a lawn mower....read the OM's !
  #64
sselvia's Avatar
sselvia
Ummhmm......they sure do!
Old Jul 26, 2017 | 05:34 AM
  #65
-=gRaY rAvEn=-
Moderator
What ?
Bill out or pour in ?
Old Jul 26, 2017 | 05:39 AM
  #66
sselvia's Avatar
sselvia
What ?
Oh, sorry, bill out i meant, for sure. I'm sure they don't overfill it....well maybe some techs do, but I'll not do that to any of my vehicles. And to not mislead.....I am not a real mechanic....only in my basement! Where I'm an excellent hack!
Old Jul 26, 2017 | 06:26 AM
  #67
Qik420's Avatar
Qik420
Zactly.
Old Sep 4, 2017 | 09:59 AM
  #68
joedotmac's Avatar
joedotmac
Anyone here actually validated the anecdotal observations with scientific measurements such as used oil analysis?
Do the aforementioned oils mentioned meet the API SM, ACEA A3/B4, BMW LL-01 specifications?
Old Sep 10, 2017 | 06:46 PM
  #69
thebombardier's Avatar
thebombardier
Redline, most Liqui Moly oils, Amsoil European Car Formula, Castrol Edge, to name a few.
TREX
Nov 2, 2019 07:31 PM
Dec 23, 2015 10:36 AM
phrza81
Oct 10, 2015 11:37 PM
clintmeister
Aug 12, 2015 11:11 AM
