R56 TPMS and Tire Rotation
Old Aug 6, 2013 | 04:52 PM
breyfogle's Avatar
breyfogle
Simple newbie question :
When I rotate my tires, will that require a TPMS reset ?
Old Aug 6, 2013 | 05:00 PM
DOtheDEW's Avatar
DOtheDEW
no, i just rotated mine yesterday and it was fine
Old Aug 6, 2013 | 07:16 PM
Big Knight's Avatar
Big Knight
I have seen other posts indicating it will require a reset. Maybe it varies?
Old Aug 6, 2013 | 10:00 PM
Velocityvic's Avatar
Velocityvic
Mine tells me to, but I usually have them balanced also.
Old Aug 7, 2013 | 05:58 AM
richardsperry's Avatar
richardsperry
Maybe... But it's not something that requires a trip to the dealer. It's a simple DIY, push the button on the turn signal operation...
Old Aug 7, 2013 | 07:17 AM
bmwr606's Avatar
bmwr606
i do a reset, but i run different pressure front vs rear
scott
Old Aug 7, 2013 | 08:30 AM
I CHA 3X's Avatar
I CHA 3X
how often are you rotating them? with other auto's i was every other oil change (every 6-7000) but since now its every 10,000 miles for that then when?????? every 5,000?
Old Aug 7, 2013 | 08:34 AM
bmwr606's Avatar
bmwr606
i rotate at 4k miles, when i change oil/filter
scott
Old Aug 7, 2013 | 08:37 AM
I CHA 3X's Avatar
I CHA 3X
Scott, aren't you on synthetic oil?
Old Aug 7, 2013 | 08:42 AM
bmwr606's Avatar
bmwr606
yes, but i think 8k miles is too long for a turbo engine to run the oil
i got the extended maintenance, so mini does an oil/filter change every 8k and i do an oil/filter change when the OBC counts down 1/2 way, ie to 4k miles
oil is cheap ... engines are expensive
scott
Old Aug 7, 2013 | 08:58 AM
I CHA 3X's Avatar
I CHA 3X
i was told 10k for oil for my gen 1 base, Brandon was confident that it was not needed sooner.
ooooh! i made it to 1st gear!!!! :D
Old Aug 8, 2013 | 12:34 AM
nrfitchett4's Avatar
nrfitchett4
maybe in a base model, but I agree that 10k oil changes are bad business, esp as engines get older. I'm shooting for every 4-5k miles.
Waszak
Oct 21, 2017 05:55 PM
renchjeep
Sep 6, 2015 01:54 PM
