R56 N18 Turbo vs. N14 Turbo
Old Aug 5, 2013 | 02:45 PM
  #26
SuperGreg's Avatar
SuperGreg
Originally Posted by Beachnmini
Oh, I have the N18. Thanks!
Lol, congrats :O
Old Aug 5, 2013 | 02:51 PM
  #27
Beachnmini's Avatar
Beachnmini
Well, it is comforting to know what I thought I knew about my newly purchased car is correct I spose.
Old Aug 5, 2013 | 02:59 PM
  #28
SuperGreg's Avatar
SuperGreg
Exactly, I would feel better too!!
Old Sep 10, 2013 | 05:10 AM
  #29
borderwave2's Avatar
borderwave2
An interesting question I would like answered is what specifically is different regarding the DME load target logic between the two engines. Over at the N18 tuning thread Terry@BMS said he plugged up an N14 car and it operated in a very different way from the N18 car that the JB+ is designed for.
I had originally hoped that the JB+ tuner would be a no brainier to adapt for the N14. Sadly it does not look like this will be the case.
Old Jan 1, 2014 | 09:29 AM
  #30
ChiliRedR56raleigh's Avatar
ChiliRedR56raleigh
N14 engine ran into 2012 with the JCW engine. The N18 came late into 2011. SO that is IMO why they say it will fit a 2012.
Wrong. The N18's came on the MCS from the beginning of the 2011 Model Cycle. Mine was made in 2010 at the end of August and it has the N18 engine.
Old Jan 1, 2014 | 11:02 AM
  #31
Braminator's Avatar
Braminator
If you have a JCW model year upto early 2012 you have a N14 engine. The MCS came with N18 in 2011 model year.
Old Jan 1, 2014 | 11:16 AM
  #32
ZippyNH's Avatar
ZippyNH
+1
Exactly right. And by JCW he means factory jcw...not the jcw KIT.
Old Jan 1, 2014 | 12:02 PM
  #33
ChiliRedR56raleigh
Yes, I know, but the OP has an MCS, and the poster who said he had an 11 MCS clubman, was told he had an N14 according to your post. The whole thing was about an MCS not JCW
Old Jan 1, 2014 | 12:04 PM
  #34
ChiliRedR56raleigh
If it is a late model 2011 you do. Check your door jamb for the production date. I believe if it is after 8/2011 then you have a N18.
This is the post that I was referencing to about the MCS's having the N18 from the beginning of MY2011, it wasn't incorporated late in the 2011 production.
Old Jan 1, 2014 | 12:05 PM
  #35
ChiliRedR56raleigh
Originally Posted by ZippyNH
+1 Exactly right. And by JCW he means factory jcw...not the jcw KIT.
Yes, I know he means the JCW model. Obviously a kit wouldn't constitute a different engine. The JCW Kit is pointless anyway. I don't think anyone thinks the JCW kit makes their car a JCW.
Old Jan 1, 2014 | 12:12 PM
  #36
Braminator's Avatar
Braminator
Go back and read the whole thread as I think you are confused.
Old Jan 1, 2014 | 12:35 PM
  #37
ChiliRedR56raleigh
I have read it twice.
Old Jan 1, 2014 | 12:38 PM
  #38
ChiliRedR56raleigh
Your post says that the JCW had the N14 thru 2012, then switched to the N18, but in a further post to a guy with an 11 MCS, you said the late 2011's were equipped with the N18. Basically, you were saying that any MCS before late 2011 was an N14 powered car.
Old Jan 1, 2014 | 12:39 PM
  #39
ChiliRedR56raleigh
So, I thought I had the N18 in my 2011 clubbie S. You're saying I may not?
This is what I'm talking about.
Old Jan 1, 2014 | 01:09 PM
  #40
yesti's Avatar
yesti
From what I read
N18: JCW 2013+, S 2011+
Old Jan 1, 2014 | 01:18 PM
  #41
ChiliRedR56raleigh
Originally Posted by yesti
From what I read N18: JCW 2013+, S 2011+
Yes, ALL MY2011 S models have the N18, not just late '11's.
Old Jan 1, 2014 | 01:33 PM
  #42
ChiliRedR56raleigh
MY2011 production began in mid-2010. His post to the guy with the clubman is incorrect, in that the N18 was being used over a year before 8/2011 like he said.
Old Jan 1, 2014 | 05:29 PM
  #43
george_talbot's Avatar
george_talbot
The MCS turbo on the N14 and N18 should be the same. Borg Warner have a few different numbers for the same turbo.
Old Jan 1, 2014 | 09:13 PM
  #44
yesti's Avatar
yesti
I dunno, realoem.com has different part numbers for them. Not sure actual manufacturer part numbers.
Old Jan 2, 2014 | 04:22 AM
  #45
SuperGreg's Avatar
SuperGreg
Can't someone just call a dealer parts dept. and get the real skinny? That's how we did it in the old days lol
Old Jan 2, 2014 | 09:27 AM
  #46
ChiliRedR56raleigh
There's a slight revision to the exhaust manifold. I mean SLIGHT
Old Jan 2, 2014 | 02:29 PM
  #47
george_talbot
The manifolds fit all the turbos. There was a stock MCS manifold, JCW Stage 1 manifold and Factory JCW manifold and all fit the stock and JCW turbos.
Old Jan 2, 2014 | 02:56 PM
  #48
1guru2's Avatar
1guru2
Our Clubbie was built 05/2011 and has the N-18.
Old Jan 2, 2014 | 04:28 PM
  #49
ChiliRedR56raleigh
Yes they should fit all, but there was a revision to the manifold at sometime, but it shouldn't change the turbo fitment.
Old Jan 2, 2014 | 05:41 PM
  #50
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
jeesh was getting a migraine reading all this....Braminator was correct in what he previously stated.
A factory JCW R55/56 and R55/566N produced up until early 2012 has the N14B engine. So if you have a 2011 MCS JCW it has the N14B. If you have a 2011 MCS it has the N18B.
Additionally, from what I have read, the turbo from an N18 engine has significant design differences making it the better of the two ( earlier R56 vs. newer ) the newer one produces boost much faster with less friction/heat due to different type of internal bearings ( needle vs. ball bearing style ) and scroll fin angle. I'll admit, I am more of a Supercharger Officiando but this is my understanding of the two Turbo designs.
