R56 Sport Button question
Old Apr 13, 2013 | 07:13 PM
  #26
Systemlord's Avatar
Systemlord
Originally Posted by bmwr606
there is ABSOLUTELY NO DIFFERENCE IN POWER OR TORQUE with the sport button on or off
the throttle pedal to throttle plate motion is linear with the sport button off and progressive with sport button on
translated to english,
sport button on, you give 1/4 throttle and the ECU gives you 1/2 throttle
sport button off, you give 1/4 throttle and the ECU gives you 1/4 throttle
scott
That actually make a lot of sense, which is why the pedal feels more sensitive. I also notice that there's less turbo boost past 4500 RPMs with Sport Mode on since you get it sooner, when your pedal is at 100% Sport Mode off there's more boost at the top-end of the RPM range. At least this is how it feels.
Old Apr 13, 2013 | 07:55 PM
  #27
JoanieB's Avatar
JoanieB
It may not give more power or torque, but a quicker response to pedal movement AND quicker shifting AND shifting at higher revs seems like it COULD be worth a second or two.
That's for the auto, of course....
Old Apr 13, 2013 | 10:22 PM
  #28
3lusive's Avatar
3lusive
scott
truth. it's all about perceived motion but mechanically there's no change.
Old Apr 14, 2013 | 03:09 AM
  #29
Ween's Avatar
Ween
*deleted*
Old Apr 14, 2013 | 03:59 AM
  #30
JoanieB's Avatar
JoanieB
Not perceived motion, that would imply that the change is in the mind of the driver. I think it's quicker car reaction, which would make the car respond and move quicker, though not faster as far as power. Eliminating the lags that are coded in to the throttle and shift points for the sake of gas economy.
Old Apr 14, 2013 | 05:23 AM
  #31
JeffHarper's Avatar
JeffHarper
Sports mode is a tool, nothing more. It is very useful in specific situations. If you don't like it, fine, but it is not a fake or imaginary feature. It changes the responsiveness of the car whether you feel it or not, whether you believe it or not.
With my auto mini, I find that in congested traffic situations in town, when I want/need extra zip it works nicely. I absolutely love the feature, but I use it sparingly. It's murder on gas mileage, so it's seems pointless to use on the freeway, at least most times.
Old Apr 14, 2013 | 06:26 AM
  #32
Chimera's Avatar
Chimera
Its funny you say that about gas mileage, I regularly drive a 45 minute section of road that's quite twisty with lots of different gradients and a speed limit of 50, and I find that I can get 3-5 more mpg if I drive it with sport mode on. Obviously on the freeway if you're using sport and not letting the car go into 6th, of course the gas mileage is going to suck. If I use sport and I'm on the freeway, I go into full manual and use 6th when I'm at cruising speed - just gives me the added responsiveness without sacrificing the range.
Old Apr 14, 2013 | 06:41 AM
  #33
JeffHarper's Avatar
JeffHarper
Hmm, interesting. You have given me an idea of how I can use sport mode in a new way, just go sport while shifting manually, very nice!
Old Apr 14, 2013 | 06:55 AM
  #34
bmwr606's Avatar
bmwr606
my dad's cms all4 is an auto
it too gets better furl mileage in sport mode
the non-sport shift program keeps it in too high a gear at too low an rpm
my manual cms all4 gets better fuel mileage in 4th at 60 mph than 5th or 6th
and gets better mileage in 5th than 6th at 70 mph
scott
Old Apr 14, 2013 | 06:58 AM
  #35
bmwr606's Avatar
bmwr606
Originally Posted by the matey
Maybe I'm just crazy but when I drive with sport mode on, sometimes it feels like the brake pedal is more sensitive??
neither the sport button or the DSC/DTC button have any effect on the brakes
ABS can not be turned off
scott
Old Apr 14, 2013 | 07:37 AM
  #36
pbedrosi's Avatar
pbedrosi
I thought the sport mode also activated the overboost mode?
Old Apr 14, 2013 | 07:46 AM
  #37
bmwr606's Avatar
bmwr606
nope, overboost is always there
Old Apr 14, 2013 | 09:15 AM
  #38
Eddie07S's Avatar
Eddie07S
Originally Posted by slowclimb
I use it when I autocross...turn it on and turn the traction control off. Other then that I use it very rarely...there are one or two places around me that I can drive the car to the point that the sport button helps.
Originally Posted by Btwyx
One of the other HS MINIs around here reckons sport mode is worth about 2s a run to him. I wouldn't know because we have an auto-sport mode mod. I find it very difficult to drive the car without sport mode on, and I can tell when the wife has forgotten to turn it on in the JCW (which hasn't had the mod installed yet), just by hearing her drive off.
unless his car is an automatic, i call BS on this
the sport button does not produce any more power
scott
Nope, not BS!
The reason is, and no one has mentioned this, that it also changes the RATE at which the throttle opens, not just the position of the throttle vs the pedal. I notice this in tight autocross courses when coming out of a sharp turn and I put the pedal quickly to the floor; it is not matter of how fast I have moved the pedal as I can feel the power continue to come on after the pedal hits the floor. The performance is much better with the sports button on.
Old Apr 14, 2013 | 12:45 PM
  #39
bccan's Avatar
bccan
Only way you're getting 2 seconds shaved off a qtr mile from the push of that button is if it fires the rear mounted rocket motor or a "150" shot of N2O! I think .2 is more like it & that would be admirable for a throttle & shift point reprogram.
Old Apr 14, 2013 | 03:32 PM
  #40
Btwyx's Avatar
Btwyx
Who said anything about a quarter mile? Autocross is about as far from a quarter mile race as you can get, it involves turning (quite a bit).
Old Apr 14, 2013 | 04:34 PM
  #41
bccan's Avatar
bccan
Oops! Sorry about that. My neanderthal drag racing brain combined "run" with multiple 1/4 fractions mentioned (about throttle openings). Will have to read more carefully. I'll bet my math is close though.
Back to my wiper blade research. Maybe I can comprehend that!
Old Apr 15, 2013 | 12:46 PM
  #42
rahul325's Avatar
rahul325
Originally Posted by OaklandMini
I use the sport button all the time, every time.
I click in the seat belt and push the sport button every time I drive.
ditto
Old Apr 15, 2013 | 01:06 PM
  #43
chrunck's Avatar
chrunck
scott
I'll have to try this. I've looked at 5th vs 6th at 60mph and they're about the same, but I haven't looked at 4th.
Old Apr 15, 2013 | 02:52 PM
  #44
Capt_bj's Avatar
Capt_bj
lower gear and higher rpm resulting in better MPG has been my MINI experience since 2002
Think about it:
Be it a turbo or a super the purpose of the charger/blower is to push more air/fuel mix into the chamber. To get the max boost the 'charger pump' must be running at full speed. So be it a Super or a Turbo, if you drive in high gear and keep your RPM down you negate the blower. It does NOTHING.
On my 02-S (supercharger) I learned that keeping my RPM over 3000, even 3200, resulted in better MPG. After I learned I never used 6th gear below 75 mph.
On my 07-S (TURBO) I'm reluctant to even try to get the speed up to where it makes a difference. But I do run 50 to 60 mph most of the time and I get 30 mpg religiously.
and there ain't nuthing the sport button does that will change this.
sport button = bling
Old Apr 15, 2013 | 03:09 PM
  #45
hsautocrosser's Avatar
hsautocrosser
Turning off traction control is definitely worth 2 seconds on a 50-second autocross course. I doubt if sport mode is worth more than a few tenths although I've never run with it off.
Old Apr 15, 2013 | 04:34 PM
  #46
rAte's Avatar
rAte
Side note to this colorful conversation...
My 13 MCS 6 spd opens the thermostat 40 degrees lower in sport mode. Verified multiple times with my torque app.
It "seems" to over boost more in sport mode as well.
Old Apr 15, 2013 | 07:18 PM
  #47
rich8363's Avatar
rich8363
On the rare occasion I forget to use the sport button, I'll know at a red light when I nearly clonk out when shifting.
To me, manual trans and the sport button ON is the only way to drive a Mini.
You took the words right out of my mouth.
Old Apr 15, 2013 | 10:18 PM
  #48
Melangell's Avatar
Melangell
Originally Posted by Slave to Felines
...sounding like a mis-tuned carburetor (AKA "burble and pop" on decel on the S models).
Amen brother! I HATE that adolescent fake crap.
Old Apr 16, 2013 | 08:45 AM
  #49
slowclimb's Avatar
slowclimb
At least it is not like VWs and some other cars where they pipe sound into the cabin or use sound enhancers.....
Old Apr 16, 2013 | 09:33 AM
  #50
axleR56's Avatar
axleR56
Except it is lol we have that too ... On S models atleast
