R56 Emergency help! Can push start!
However if mini's do have that switch to overide a blown fuse, you'll be able to shift into neutral and try this method.
my 2 cents: with the safe/reliable function of the brakes in question, might be better NOT to attempt to get the car back on the road. So you get moving again and what if you need to brake and nothing happens? YIKES!
Thank you and Braminator soooo much for your help. tomorrow morning i will try it all and let you know what happens, and this will be a great help to others who may experience this problem.
Not sure about Mini but other cars brake boosters can cause a stiff pedal when the vacuum from the engine isn't available to relieve it. You could look for a switch on/near the brake pedal that tells the ecu the pedal has been depressed and manual manipulate it with your hand possibly to get it to start. Then the brake booster may reset it self.
Just my advise, not a professional mechanic, but I have worked on lots of cars and Uhaul trucks for a few years.
UPDATE: it turned on with a little struggle this morning and i took it to the mechanic. The volts were around 10 which is low for cars with push start so the battery was changed. The car still doesnt turn on as fast as it should perhaps because of the cold and starter. I will keep you posted tomorrow and let you know if the starter had to be changed as well. So peace of advice if your car doesnt turn on the first time it could be this! Not the fact that you didnt push it down enough. i just hope its not too much have anyone had to replace their starter before?
Hahaha how was the most obvious thing overlooked
]The car got my brakes done earlier today and im tryn to start the car and the brake wont go down
Hey i had to inform you guys about the previous activities
get every possible solution and someone did tell me to start it the next day, but yeah not enough voltage on start up so trip to philly maybe cancelled :( at least in my darling Mini
Etrain
16
Aug 5, 2024 04:37 AM
Drivetrain Help on MAF Sensor Clip - Cannot Remove
Motown
Apr 20, 2018 09:31 AM
LordOfTheFlies
Oct 19, 2015 05:02 PM
