R56 Codes P1338, P0011, P0014 after multiple resets.
Old 01-01-2013, 06:49 PM
mellowmini's Avatar
mellowmini
mellowmini is offline
Hello I just purchased a 2007 Mini R56 base model with 112k highway miles. The check engine light is on. I have codes P1338, P0011, P0014 after multiple resets. I hear no chain rattling noises in the engine what so ever. The cars surges and idles poor on start-up and seems to lack power in the low rpm range and will occasionally stall coming to a stop when cold. I changed the 2 cam position sensors around and still have the same fault codes. I took the valve cover off and visually inspected the chain, chain tension and guides and saw no problems. I thought I may replace the chain tensioner before going deeper and more expensive even though no noise. Can anyone shed some light on my issues and what I should try next? I try to avoid the dealership and do the work myself. Below are some of the common answers to the codes based on some research.
P1338 Camshaft Position Sensor bank 1 open circuit or short to positive.
This could be is a failure of the Camshaft Position Sensor or a short in the wiring?
P0011 camshaft position timing bank 1‎
Can you reset the cam timing ?
Could this be timing chain jumped or stretched?
P0014 - Camshaft positioning sensor actuator B timing
Incorrect camshaft timing
Wiring problems (harness/wiring) in intake timing control valve control solenoid system
Continuous oil flow to VCT piston chamber
Failed valve timing VANOS solenoid (stuck open)
Thanks,
Mellomini
Old 01-01-2013, 07:45 PM
Braminator's Avatar
Braminator
Braminator is offline
Do you know if the chain was serviced? Also have you tried do a reset?
Old 01-01-2013, 08:04 PM
mellowmini's Avatar
mellowmini
Service History
Hello Braminator,
I have no service history details on the car. Yes I reset the check engine light multible times.
Thanks,
Mellowmini
Old 01-01-2013, 08:35 PM
Braminator's Avatar
Braminator
You need to try replacing them with a new one.
Old 01-02-2013, 09:33 AM
mellowmini's Avatar
mellowmini
place an order for 2 new Cam Position Sensors
Hello Braminator,
I just place an order for 2 new Cam Position Sensors today. I will install them and report back with my findings. I am hopefull that it will correct the problem.
Thanks,
Mellowmini
Old 01-02-2013, 09:37 AM
Braminator's Avatar
Braminator
Good luck.
Old 01-09-2013, 07:06 PM
mellowmini's Avatar
mellowmini
New Code P115D
Hello,
I change out the cam position sensors and it may have eleminated the codes P1338, P0011 and P0014. The engines power came back.
Now I am getting the code P115D. (P115D Mass or volume airflow A too high) I tried to clean the mass airflow sensor. I also unpluged sensor and the engine just dies. I also checked for unmetered air leaks and found none. Any suggestions on what to do next?
Thanks,
MellowMini
Old 01-09-2013, 07:21 PM
Braminator's Avatar
Braminator
Well you are getting there. Glad to see the sensors worked out.
Now as far as your code P115D Check your intercooler hoses and make sure they are on tight and the clamps are secure.Check especially the passenger side.
Old 01-09-2013, 07:38 PM
bluefox280's Avatar
bluefox280
bluefox280 is offline
* MINI DTC P115D (0x2774, 0x2B55, 0x2B57, or 0x2B5B) - Mass Air Volume (MAF) Flow 'A' Too High
The ECU is seeing, via the MAF sensor, too high of rate of air being pulled into the intake system.
- Erik
Old 01-09-2013, 07:45 PM
Braminator's Avatar
Braminator
These are air system related codes. Make sure all the boost tubes from the turbo intake to the throttle body are tight. Check the tubes on the intercooler.
Old 01-09-2013, 07:46 PM
Braminator's Avatar
Braminator
Old 01-10-2013, 11:33 AM
bluefox280's Avatar
bluefox280
On a base (Justa) model, as mellowmini noted in his first post, there is no turbocharger and therefore no boost tubes.
However, he should check the intake tubing and manifold for any leaks or loose connections.
- Erik
Old 01-10-2013, 11:36 AM
Braminator's Avatar
Braminator
I guess I missed that part in the 1st line
Old 01-14-2013, 08:33 AM
mellowmini's Avatar
mellowmini
Hello Braminater, The check engine light came back on with the same codes P1338, P0011, P0014, P115D after multiple resets. So I decided to remove the Vanos solenoids. When I removed them, I was shocked to find that the screens were clogged with aluminum metal shavings. The previous owner seems to have ran the car low on oil from the leaking valve cover gasket I just replaced. Right before I found the metal shavings, I had changed the oil and the filter at a station with mobile 1 synthetic and the tech mentioned it was dirty.
I have now cleaned the screens and reinstall the solenoids and change the oil and filter once more. The car seems to now run great now and so for no check engine light. I am planning on change the oil and filter at every 50, 100, 200 miles intervals several more times and see what happens.
The engine seems to be running normal and no unusual sounds. I am worried about the engine scoring and the metal shavings and would like to find a way to get all the metal out of the engine quickly. Does anyone have a suggestion or commits?
Thank You,
Mellowmini
Old 01-14-2013, 08:37 AM
Braminator's Avatar
Braminator
I am worried about the engine scoring and the metal shavings and would like to find a way to get all the metal out of the engine quickly. Does anyone have a suggestion or commits? [/FONT][/SIZE]
Where did you buy it? I would still be concerned about metal shaving being in there. Any pics?
Old 01-14-2013, 08:56 AM
mellowmini's Avatar
mellowmini
I aquired it for $3500 from the original owner that gave me no details other than she thought the engine had a problem.
Mellowmini
Old 01-14-2013, 08:59 AM
Braminator's Avatar
Braminator
Guess she knew, and not thought. This is a case of buyer beware. Sorry to say that. But you did get a 2007 MCS for $3500.00. That should of been the 1st clue. IF you say you cleaned things and change the oil and all is well, then great you got a great deal. IMO be prepared for more things to come. You might of got lucky though. Time will tell.
Old 01-14-2013, 09:02 AM
mellowmini's Avatar
mellowmini
I did not take any the first go around. I will send some pics of the next oil change. I will also remove the Vanos solenoids again and inspect it for more shavings and take a photo of them as well and post it.
Mellow Mini
Old 01-14-2013, 09:31 AM
mellowmini's Avatar
mellowmini
Hello Braminator,
Yes I took a big risk when I purchased it.
MelloMini
Old 01-15-2013, 08:09 PM
mellowmini's Avatar
mellowmini
I got the P115D code again after multiple resets. I can’t seem to find any air leaks and everything looks in order. There is no vacuum noise present. The vacuum plumbing is real basic because this is a non-turbo model. I plan to check to the brake booster, intake manifold and the PCV valve and the end of the PCV tube that goes under the intake manifold. Is there anything else I should check?
The car is now running well and has lots of power. I checked the VANOS oil solenoids and they only had a few very fine flecks of metal present on the screen. This seems to be a good sign. I will change the oil for a third time this weekend.
Thank You,
Mellowmini
Old 03-02-2013, 11:03 PM
scottda3's Avatar
scottda3
scottda3 is offline
What is the steps to reset the ECU on the R56?
Old 03-03-2013, 02:16 AM
mellowmini's Avatar
mellowmini
Hello Scotta3,
I am assuming that your check engine light is on and you would like to find out what the codes are and clear them. Here are steps and options.
  1. Locate the ODB II connector under the dash pannel. It is located on the drivers side foot well to the far left. The ODB II connected has a small plastic cover over it.
  2. Remove the cover and attach a ODB II scanner scanner cable. Any generic ODB II code reader will work.
  3. The scanner will give you the option to read the codes present. write those code down so you can use it to do some research into you issue later. (If you do not have acces to a ODB II scanner AutoZone has one you can use for free.)
  4. After you have the codes, the ODBII scanner will have a drop down menu area that will give you the option to clear the code by resetting.
  5. Now that the codes are cleared, drive the car and see if the check engine light come back on.
If you do not have access to a scanner, you can remove the battery cable from the battery for about an hour and it will clear the check engine light as well. By doing this type of reset the ECU will zero it self out and go back to factory specifications and the car will re-learn the and re-adjust its self after restart.
I hope this information helps you and good luck.
MellowMini
Old 03-03-2013, 06:50 AM
Braminator's Avatar
Braminator
So did you get this sorted out?
Old 03-04-2013, 07:17 PM
scottda3's Avatar
scottda3
scottda3 is offline
Mellow thanks for the info
Old 03-04-2013, 07:29 PM
Braminator's Avatar
Braminator
Quick Reply: R56 Codes P1338, P0011, P0014 after multiple resets.
