R56 Leak at thermostat?
Old Oct 2, 2012 | 07:15 AM
bigbacon's Avatar
bigbacon
Leak at thermostat?
Is this a normal mini fail point? car is an 08 with 23,000 miles on it
leak at thermostat housing
leak at one of the transmission joints.
geeze...
plus broken window regulator....
Old Oct 2, 2012 | 11:13 AM
schatzy62's Avatar
schatzy62
with this amount of years on it possibly. Many people recently have been having problems with the thermostat yet two years ago there was no real complaints. It is unfortunate but not really hard to change and about $120 for the part.
this is not so familiar on the boards here.
geeze...
and there is not really a "window regulator" on these cars. What is happening with the windows?
The windows are all computer controlled for distance travel etc so depending on the exact problem there may be an easy fix or it may need a reprogram by someone with the proper tools to do it.
Old Oct 2, 2012 | 11:40 AM
bigbacon's Avatar
bigbacon
dealer said total cost for everything was $2300 bucks but I owe them only $100 bucks.
Beats me having to figure out how to fix it myself and the time.
the window stopped doing its little up/down when you open the door and if you had the window down, it would never go up all the way unless you did it in little bits at a time. Also the passenger side window started actually going down if you were trying to raise both windows at the same time. very weird the first time that happened.
i tried the window reset thing to no avail.
Old Oct 3, 2012 | 10:01 AM
cheezehead's Avatar
cheezehead
I just had a leak at the thermostat a week ago. the thing was, is that the dealer replaced the thermostat last month, so its their fault.. gotta watch the dealers on the work they do now too..
Old Oct 3, 2012 | 01:56 PM
Fly'n Brick's Avatar
Fly'n Brick
Don't say where you're from but check out soopercooperinfo.com and find an independent near you and get a second opinion. There is an aftermarket gasket for that thermostat that will not fail as readily as the oem part.
Cruzer214
Oct 11, 2015 07:45 AM
donniedarko
Sep 29, 2015 01:16 PM
silence2-38554
Sep 28, 2015 12:19 PM
Nicefeet
Sep 27, 2015 11:14 AM
rt808
Sep 25, 2015 01:59 PM
