R56 Brake Vacuum Pump Delete
Old Sep 17, 2014 | 04:08 PM
  #26
justawatcher's Avatar
justawatcher
Excellent ... I have a non turbo and was thinking of doing the same thing. Thanks for the post.
Old Sep 18, 2014 | 05:43 AM
  #27
Originally Posted by tecnica
Well done ECS Tuning, well done
ECS just added this pump onto their website at $213 preshipped
Thanks , it went up a hair more. But its right here:
http://www.ecstuning.com/Search/SiteSearch/11667556919/ES2681339/
Old Sep 18, 2014 | 01:56 PM
  #28
Systemlord's Avatar
Systemlord
I will replace my vacuum pump when I have the cash to just through around, call it preventative maintenance and piece of mind that my original pump doesn't take the entire engine with it. Cheap insurance.
Old Nov 29, 2014 | 01:05 PM
  #29
francisco_vazgarcia's Avatar
francisco_vazgarcia
Originally Posted by francisco_vazgarcia
Any thoughts on how to eliminate the noise with original pump? Even though it can comeback? I just changed the pump and nothing changed...
Is it possible to change the coupler for instance?
Anyone please? I have looked at realoem and cannot find any coupler, only the pump itself (which is new) or the camshaft
Old Nov 30, 2014 | 04:05 PM
  #30
nicsmini's Avatar
nicsmini
The coupler is part of the pump and cant be changed separately....you're going to have to live with the noise if you've changed the pump and it's still the same....unless you remove the existing vacuum pump and change everything over to an electric vacuum pump but that's pretty involved job
Old Dec 5, 2014 | 02:34 PM
  #31
Did you get a new pump ? Maybe a new defective pump. We have the new one above. Make sure its the vacuum pump and not something else.
Old Jul 29, 2015 | 09:14 AM
  #32
howieschoon's Avatar
howieschoon
Glad I stumbled upon this today. Having a simple part like a vacuum pump that can grenade an engine (even if it is rare) makes me rather worried and I might do this just for that reason. I burned an exhaust valve last year and spent over $2000 rebuilding the head and replacing some parts...and another $1000 replacing a VANOS unit that was bad apparently, I would be rather unhappy if my investment was destroyed because a vacuum pump locked up.
Elsinorej, any thoughts on tying this in with the PCV, to pull a vacuum on the crankcase as well? My guess is that the pump is not meant for that and wouldn't flow enough air to work. It was just a thought. For the plate, would you consider making another and how much would you charge? I have some friends in the machining business that might also be able to make it but since you already have one, that would be easiest by far Now I need to decide if I actually want to do this, it would help me sleep at night...
Old Oct 2, 2015 | 01:16 PM
  #33
nomar116's Avatar
nomar116
Same noise, same thoughts. I want this rattle can noise gone!
Old Oct 19, 2015 | 07:00 AM
  #34
New lower price on the vacuum pump. Just wanted to let you guys know.
Old Oct 19, 2015 | 05:14 PM
  #35
tecnica's Avatar
tecnica
holy cow ECS - $120!
Everyone should change this on preventive maintenance alone
Old Oct 20, 2015 | 08:22 AM
  #36
You are welcome.
Old Oct 22, 2015 | 10:13 AM
  #37
IDoSeaDoo's Avatar
IDoSeaDoo
Why can't I just install an electric vacuum pump?
Do I have to have the expansion chamber and all the fittings that were utilized in the example vacuum pump conversion? Why not just use a vacuum switch inline with the vacuum pump and attach it where the old one attached? Would be much more simple IMO.
Old Oct 23, 2015 | 05:44 AM
  #38
IDoSeaDoo's Avatar
IDoSeaDoo
I'm starting to suspect the noise really IS normal...
I stumbled on a thread somewhere that showed one of these pumps all taken apart, and it appears that it depends heavily on being provided a good supply of oil. With MINI's ridiculous suggested oil change interval, and recommending a weak oil (Castrol not known to be a high-mileage oil), it's no wonder why so many pumps have seized. I believe it was this thread that pointed out that the noise is coming from the coupler. It's unlikely that the coupler is what makes the pump fail, but rather lack of lubrication of the sleeve bearing.
I plan to take mine off and carefully inspect the bearing and oil passage, and maybe see if nothing can be done about the coupler to maybe snug it up into the cam better.
Old Oct 23, 2015 | 11:41 AM
  #39
sub3622's Avatar
sub3622
I hate that vacuum pump noise. MINI stated that the noise is normal. There is a TSB about that.
Old Oct 23, 2015 | 11:50 AM
  #40
IDoSeaDoo's Avatar
IDoSeaDoo
Mine actually seems to go away to a huge extent once warm. It definitely doensn't have that knocking quality to it like when it's cold.
Any word if we can just sub in an electric pump with a vacuum switch and not the rest of the stuff as the OP states?
Old Oct 23, 2015 | 03:57 PM
  #41
SPRINTCARS's Avatar
SPRINTCARS
Someone needs to come up with an electric pump kit so the entire pcv system can be thrown in the damn trash can.
Old Oct 24, 2015 | 01:39 PM
  #42
sub3622's Avatar
sub3622
Yeah, once engine is at normal operating temperature noise is gone. Would like to know why.
Old Oct 25, 2015 | 03:02 PM
  #43
R56BrgMcs's Avatar
R56BrgMcs
Yes they do.
Old Oct 26, 2015 | 06:18 AM
  #44
IDoSeaDoo's Avatar
IDoSeaDoo
I wonder if heat expansion is the reason?
We all know things get bigger when they heat up. Maybe, once the coupler expands a little, it fits more snugly in the cam slot, reducing the knocking... Just a guess, not sure what type of metal it's made of or anything.
Old Mar 17, 2016 | 06:39 PM
  #45
donniedarko's Avatar
donniedarko
I replaced mine, very easy.
Peace of mind.
Old Mar 17, 2016 | 07:36 PM
  #46
Lex2008's Avatar
Lex2008
Some pics of the internals are here:
https://www.northamericanmotoring.co...ml#post4157883
Old Mar 18, 2016 | 10:22 AM
  #47
sub3622's Avatar
sub3622
Donniedarko, did you have the vacuum pump noise before? what about now that you have the new pump in?
Old Mar 19, 2016 | 09:03 AM
  #48
donniedarko
Yes of course. The pump and motor noise is typical it seems of all N14's. However the ticking is tighter and cleaner now. When I pulled the old unit doing a visual a testing by hand the action of new to old was obvious. Very satisfying replacing. The poor sods motors who blew up because of this part is hectic. I'd love to install an electric one it honestly this car is a PIA and I just want it driving uneventfully
Old Mar 19, 2016 | 04:01 PM
  #49
sub3622's Avatar
sub3622
Thanks, i will be replacing mine. How many miles on your r56 when you changed the pump?
Old Mar 19, 2016 | 08:19 PM
  #50
donniedarko
I actually have a r55 51k 10' as I understand same power plant. I just read about a guy with a car he's parting out from the pump detonating. No thanks
