R56 First Oil Change and storage
Old Jun 16, 2012 | 12:33 PM
Goliath79's Avatar
Goliath79
Completed my first oil change today...that was easy...(minus the oil filter, hasn't arrived yet and I'm deploying)...
Just under 2k miles on the car, I figure I'll change the oil again when I return and the filter...haha
Anyways, as I'll be leaving soon, any suggestions on what I should do with the car while it basically is in storage for 6+ months? It will be out of the weather inside a garage.
BTW, I have used the Pela Oil extractor twice this weekend (my Mini and the wife's Audi A4). I've got to say I love that thing. Pulls all the oil out and no mess. Makes my life easy!
Old Jun 16, 2012 | 12:55 PM
Chris(CA)'s Avatar
Chris(CA)
Pump up the tires high to limit flat spots?
I have a pela pump too, it's so handy for quick oil changes
Old Jun 16, 2012 | 01:32 PM
Maugre's Avatar
Maugre
If you can get it off the ground, better yet. Then put on a battery tender, and you should be good to go.
God speed and thanks for your service.
Old Jun 16, 2012 | 01:33 PM
bmwr606's Avatar
bmwr606
disconnect the negative battery cable and secure it so it cannot make contaqct with the negative battery terminal
get a "storage" type trickle battery charger
ideally, put the car on jack stands or blocks with no weight on the tires
when you return, change the oil and filter again
scott
Old Jun 16, 2012 | 04:39 PM
Slave to Felines's Avatar
Slave to Felines
Sta-bil in the gas, as well. Full tank (not much air in the tank) to help reduce evaporation.
Old Jun 17, 2012 | 12:21 AM
turboguy327's Avatar
turboguy327
Dont put the car on stands unless you are sure the suspension is compressed. Its not a big deal at all though. Id leave it down. Much easier and safer. Full tank of fuel, some fuel additive, park the tires on cardboard or I prefer a thick old rug, a battery tender and leave it alone. Leave the battery hooked up. Don't have anyone start it. Just leave it until its coming out of storage.
Old Jun 17, 2012 | 03:57 AM
flanders621's Avatar
flanders621
I wouldn't worry too much about putting it on stands. I was in Korea for a year and just pumped up the tires, disconnected the battery and put some sta-bil in the tank. Had no problems when I got back. Good Luck and Godspeed!
Kimolaoha
Jul 5, 2023 01:04 PM
woodstudio
Mar 15, 2020 08:28 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
patpatpat
Aug 27, 2015 07:51 AM
ludedude
Aug 10, 2015 07:16 PM
