R56 Diverter Valve Screw Problems
Old Jun 14, 2012 | 08:10 PM
Dek766's Avatar
Dek766
I'm getting the ALTA bov spring tomorrow, but i'm having problems getting the valve off. There's 3 screws, but one of the three is stripped in the center. Any ideas on how I could get the stripped one off? I appreciate it.
Old Jun 15, 2012 | 03:11 AM
countryboyshane's Avatar
countryboyshane
I was going to say a reverse drill bit, but there is practically no room in there to be sticking a drill. You might want to try using a slightly bigger hex bit like a 6mm for example and gradually tapping it in there.
Last resort would be CAREFULLY using a welder to weld some kind of nut on top and wrench it out. Don't forget to disconnect that negative battery cable!!!
Old Jun 15, 2012 | 05:19 AM
SooperCuperErik's Avatar
SooperCuperErik
take a torx bit (QUALITY ONE), not the cheap china ones.. thats slightly bigger than the hole in the screw, and start tapping it in... nothing pounding, but good light tights like a door knock. And when you think you're done tapping, keep tapping for another 5 minutes. Literally.
I've seen this done countless times on pulley bolts, suspension parts, etc. The key is to keep tapping, even though you're doing nothing, its still marginally going further into the head every time, and you really only have one try at it, so you gotta get 'er right.
Old Jun 15, 2012 | 12:30 PM
Dek766's Avatar
Dek766
Will try that Erik, otherwise I have no chances. I just have to get it started, and then i'll be able to get it off. I ordered the Alta BOV spring, so i need to get this sucker open.
PEterChoqu
Aug 26, 2015 08:33 AM
Chasp
Aug 25, 2015 06:36 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
eliseo1981
Aug 6, 2015 05:00 AM
