R56 PCV delete. Possible Isues resulting....
#51
So, I should:
1. Block off PCV on passenger side.
2. Hook OCC on driver's side PCV / be cheap and run hoses to drip.
And hopefully I will lengthen the time between walnut blasting my valves.
Am I getting this right?
Here's a link for reference: http://www.meetup.com/Central-Maryla...hread/23860862
#52
So, I should:
#53
#54
OP here, I made an adapter for the dipstick hole that I can monitor the actual crankcase pressure to the .01 psi. I tested it last year sometime but can't remember what the actual numbers were. I will retest with videos showing the results when I get a chance.
On the draft tube topic if one were to install draft tubes why not use the exhaust system to evacuate the crank case. Here is a link to a V8 system.
http://www.summitracing.com/parts/mi...FexDMgodahsADA
It must be welded into the exhaust pipe.
#56
Advice needed...I have a BSH OCC and plugs and was all set to do the traditional PCV delete. Then I started reading about possible consequences and got cold feet. However, since the passenger side PCV is considered the main culprit for carbon buildup, would it not be a decent solution to just put the OCC on THAT side instead of the turbo inlet side? I would leave the OCC mounted as is and run in/out lines along the back of the engine. That is if I can figure out how to connect the hose on the passenger side PCV.
#57
Pcv
Its not just controlling crankcase fumes to atmosphere but using vacuum to facilitate this process. I just ran hose from both valve cover vents (one is a pcv) and routed to 2 oil catch cans then routed initially to atmosphere BUT.... this created an issue as the DME was looking for additional air, albeit with oil and stuff from the crank to keep the A/F ratio proper. I could not figure out why my car was running rich during WOT. When I rerouted the hose from the oil can baclk to the turbo inlet, the rich condition vanished.
Like I said in my first post. The only real reason we have PVC is to prevent pollution.
Good to know. I wasn't sure positive how modern engines were designed. Old engines just had breather filters and draft tubes.
Now that we have this established. Can we go back to the PVC system. To reiterate my point that as long as there is a way for the pressure to escape it should be fine. If the passenger PVC port is open then where is the problem coming from?
Now I'm not trying to be rude. I am curious. I would just like to clear up some stuff up.
#58
I've got a OCC that I'm going to put on the driver side port. I'm on the fence about plugging up the passenger port, at this point I'm going to leave them be. If the OCC doesn't have enough of an effect on carbon buildup then I'll get a plug for the PCV.
A yearly SeaFoam treatment before an oil change will hopefully keep the carbon Buildup at bay.
#59
Most of the crankcase gasses go out the passenger side port and to the throttle body when the car is not under boost, so the back PCV hose is the source of most, if not all, of the oil that causes carbon build up, on an N14 engine.
I have a boost/vacuum gage in my MINI, in my normal driving, that gage is hardly ever in boost.
When you block the rear PCV hose, all of the crankcase gasses go through the driver's side PCV line and through the oil catch can and then the turbocharger.
We know that oil catch cans are not 100% effective, so some of the oil and other gasses will go through the turbocharger even with an oil catch can. I don't think much of the oil vapor actually gets to the intake ports via the turbocharger route as there is a lot of piping, and the intercooler to go through before any oil could get to the intake valves.
I think that if you are installing an oil catch can on a N14 engine, it won't prevent carbon build up unless you also block the PCV line on the passenger side of the headcover.
Dave
Dave
#60
I get what you're saying about the Driver side port being effected by the turbo pressure.
#62
So once the oil enters the intake stream where does it go? Does it just disappear?
#64
All of that oil ends up in the intercooler, that isn't a solution to oil consumption. The oil eventually will reach the intake pooling up in some areas and when you step on the gas you will get oil and blue smoke out the tail pipe. Return the PCV system back to stock and have your intake system and valves media blasted every 30-50k and call it a day.
#65
#66
Hi all, i know this is an older post and i have red so much about the problem i have with my 2009 MCS that i really am confused now. my problem is long idle at the light or traffic, you got it the smoke.my tech has gone through my car and there are no leaks cylinder test at about 170. no ruff idle car runs very strong a/c will freeze your bud.
so last week he told me it may be the valve cover or i need an OCC since he found a lot of oil in the turbo intake and the vacuum line.
what should i do??????????
#67
I think there may be something else going on besides just going back to the stock PCV configuration that reduced oil consumption and smoke.
I have the BSH dual boost port, which blocks off the PCV line to the intake manifold like the Peugeot delete plug does. As well as a BSH Catch can on the PCV line to the turbocharger.
I installed these just after buying my MINI.
In the nearly three years of having this set up, my MINI has used no oil, other than 1/2 a quart when the engine was breaking in. I have not had any smoke either. I check my oil level and the level in the oil catch can weekly.
Like I said, there must be something else going on, if just putting the PCV line from the cam cover to the intake back solved your oil consumption problem.
Dave
Dave
#68
No big smoking guns found, will monitor oil level changes to see if the $$$ parts replacement/work helped, might take a month , as I drive less.
#69
#70
The passenger side is the one (U.S. cars) that should be blocked off, that is the one that goes to the throttle body and allows crankcase fumes, including oil vapor, into the head where oil bakes onto the backs of the intake valves. The PCV hose on the driver's side should then go through an oil catch can and then to the turbocharger inlet.
Blocking off the PCV line to the turbo, (drivers side) will cause the crankcase to pressurize when the engine is under boost and cause major oil leaks.
#71
#72
You should have an oil catch can on the driver's side PCV line, not a vent or filter. Get a good oil catch can, one with baffles, to keep the crankcase vapors in the can longer so they can condense and drop into the can. A simple vent or filter will not provide a low pressure area to draw the crankcase vapors out of the engine. The turbocharger intake provides that low pressure source to pull the crankcase vapors out of the engine.
Even back in the fifties, cars had a draft tube that extended from the crankcase to under the car into the air stream to cause a small vacuum to assist the crankcase vapors out of the engine. Don't put a draft tube on a modern engine, it will stink and drip oil under the car.
#74
I just installed a system in my 07 where I routed both PCV ports to a single catch can and then vented it back just upstream of the turbo. This way, regardless of what the PCV valve system is doing inside the valve cover, the engine has a way to breathe. Seemed like the most logical approach to me.
#75
the catch can is catching stuff again and the oil consumption is down, I'm about 70% sure that the problem has been fixed with a new valve cover, and a walnut blast.
