R56 Need input on plug wires...
Old Mar 28, 2012 | 01:36 PM
surfin'02's Avatar
surfin'02
I have an '07 MCS with ~45k miles. I was wanting to proactively replace the plugs and plug wires. Any recomendations?
Old Mar 28, 2012 | 03:16 PM
strobeyprobey's Avatar
strobeyprobey
Plug wires are going to be found in the same spot as the power steering fluid.
(There are none, as it is coil-on-plug). OEM plugs are good way to go. You need a special 12-point thin wall socket. I just replaced mine.
Old Mar 28, 2012 | 03:17 PM
countryboyshane's Avatar
countryboyshane
You can't replace the "wires" on this car. There are four separate coils for each cylinder. The main wire harness attaches to each coil with a levered connector on top of the valve cover. The stock plugs are good for supposedly 100K miles. I would just take a look at them and see if you really need them or not. A new set is going to run you around $60.
BTW, the R56 has an electrically assisted power steering rack. There is no power steering fluid.
Old Mar 29, 2012 | 04:04 PM
AustinS's Avatar
AustinS
Originally Posted by countryboyshane
BTW...There is no power steering fluid.
I think that's what strobeyprobey was saying
Old Mar 29, 2012 | 06:39 PM
surfin'02's Avatar
surfin'02
Thanks everyone! Just been schooled!
Old Mar 29, 2012 | 06:46 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
With that mileage it's not a bad idea to replace the spark plugs, but at least you don't need any wires.
Filmy
15
Jun 6, 2023 06:27 AM
QuickCooper
Dec 29, 2016 06:46 PM
rob76turbo
Sep 15, 2015 10:11 AM
Norton70
Sep 11, 2015 12:16 PM
Ntety
Sep 2, 2015 08:39 PM
