R56 A few dumb clutch replacement questions
Old Mar 19, 2012 | 02:37 PM
thinkinmini's Avatar
thinkinmini
So I'm in the process of replacing my clutch, gotten pretty far I suppose for one day. Subframes out, exhaust is out, etc etc.....but I've got a few questions....Did you place your radiator into service mode, or remove it and the support completely when replacing the clutch? Or was there some way around this? If there was, what was it? Also if you removed the radiator/support, what are the steps involved with that? And what fluids needed to be drained, if any? I know it's a dumb question, but did you drain the clutch and the trans of fluid before pulling out the units? And what did you use to seal the units of the trans/clutch back together, was it anaerobic flange sealant as specified in the writeup by lonestar mini club? Thanks for all the help, I truly appreciate it.
Old Mar 19, 2012 | 07:58 PM
kukaepe's Avatar
kukaepe
If you don't have a Bentley manual to guide you through this repair, I suggest you order one here: http://www.amazon.com/MINI-Cooper-R5...2212257&sr=8-3
Old Mar 20, 2012 | 04:37 PM
thinkinmini
I was trying to avoid that, but it looks like I may have to bite the bullet. I'm a good way through the repair, subframe's out, bumper/bumper cover are off, radiator support has been extended (but I might need to drain the radiator to extend it farther), and I even popped out the driver side drive axle. Any trick to the passenger side axle, or is it the same?
andrewjg1994
Jan 29, 2021 07:45 PM
eliseo1981
Jan 28, 2021 02:45 PM
PrimePower
Aug 16, 2015 06:29 PM
Powershift
Aug 16, 2015 05:14 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
