R56 Purpose of vent in rear sill cover?
Old Feb 20, 2012 | 02:54 AM
d@g's Avatar
d@g
When I had my MINI interior out for sound deadening (prior to my custom RSD project), I noticed the rear sill cover has a vent across the front of it, with a foam "filter" behind it. (My filter was covered in dog fur). The sill cover goes over a hollow beam with two oval shaped holes in it.
Is this some type of passive ventilation? Air pressure relief? The vent actually lets quite a bit of noise in from the rear of the car (squeaks from wheel wells, bumper skin and if your spare is not attached perfectly, the spare tire. I slid a piece of close-cell foam into the slot and it cuts out quite a bit of noise -- just wondering if there will be side effects (window fogging, air pressure, etc.).
This may only apply to Justas, not sure about MCS. Thanks.
Old Feb 20, 2012 | 07:22 AM
mamut's Avatar
mamut
I believe it's for air pressure relief when closing the hatch
Old Feb 20, 2012 | 07:45 AM
jrammon's Avatar
jrammon
Can you post a pic of the vent? Thanks
Old Feb 20, 2012 | 08:39 AM
Bilbo-Baggins's Avatar
Bilbo-Baggins
It serves two purposes; pressure relief when closing the boot and passive flow through ventilation while driving around
Old Feb 20, 2012 | 12:11 PM
d@g's Avatar
d@g
Here you go. Sorry for the dog fur/dirt. It's not the full back, but you get the idea. On the right you can see my rear-seat-BELT-delete cover (first prototype).
The metal under the sill cover looks like this (see part number 3 in the diagram below):
Old Feb 20, 2012 | 04:08 PM
rkw's Avatar
rkw
The vents have been there ever since the beginning (1st gen). As mentioned, they are for ventilation and pressure relief. The topic has come up before and people have said that the AC doesn't work as well when the vents are blocked.
wkp1219
Nov 13, 2015 07:52 AM
Shane Wendel
Aug 21, 2015 01:04 PM
OutMotoring
Aug 6, 2015 09:32 AM
