R56 I should be making more boost than this - right?
Old Feb 19, 2012 | 11:55 AM
Z06C5R's Avatar
Z06C5R
Quick and easy - 2010 fJCW, Alta CAI, and resonator delete. The car hasn't quite had the ***** it did back last fall when I picked it up, and I've not seen more than 15-16psi on my boost gauge since I put it in a month or two ago (Autometer mechanical gauge reading off a NM boost tap).
From what I'm seeing, a fJCW should make more like 19-21psi in stock form, right?
Old Feb 19, 2012 | 03:27 PM
onefish2's Avatar
onefish2
That is about right. Maybe even a bit high.
If you are tuned you may see 19 to 22 psi or more.
I have a 09 JCW with a RMW tune. I see 20psi on a regular basis. I have the VEI hi res digital boost/vacuum gauge that get its reading from the BSH OCC boost tap.
sevin
May 2, 2026 06:11 AM
AdrenaliNate
Nov 4, 2015 07:26 PM
dscott90000
Aug 23, 2015 08:21 PM
Indimanic
Aug 19, 2015 11:08 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
