R56 sudden turbo lag?
Old Jan 16, 2012 | 05:56 AM
  #26
cereal's Avatar
cereal
Originally Posted by MiniDeLux
If you're not concerned about the warranty too much, I suggest getting the clutch changed at an independent garage, rather than the BMW/Mini dealership. An independent will be considerably cheaper (although still expensive), but you won't have the same guarantee coverage.
Getting your vehicle serviced by an independent garage will not void your warranty or limit MINI's liability. Certainly you may have a different warranty on the work and parts provided by the independent garage, but most places will do just as good as BMW/MINI on the work they provide. Given that changing a clutch is labor intensive, why pay the BMW labor rate? It can get quite ridiculous. Shop around and find a good garage. Your wallet will be happier and you'll likely find a better shop than the dealer (at least that's been my experience).
Old Jan 17, 2012 | 09:13 AM
  #27
Thruxton's Avatar
Thruxton
Originally Posted by Snake20
Car went in at New Country Mini today. They found codes for bad timing, poor spark, and thermostat for the cabin. Thermostat isnt really a part of the problem. They said I'm looking at a full timing chain kit (about $1500)and new plugs to fix the problem. Good to know the problem and glad I caught it before it was fatal but this still sucks... I contacted MINI USA to see if they will help with the timinig chain fix and will hear back from them in 1-3 days.
Are they going to help you?
Old Jan 17, 2012 | 10:23 AM
  #28
Snake20's Avatar
Snake20
Finally heard back from MINI today and they're not gonna help me out at all. They're rational is that since the car is no longer under warranty they're no longer liable. Not much else I can do so I'll just have to suck it up and pay... Open to some suggestions if you guys have them tho. Still it's tough to swallow that a car with under 60K would have a timing chain probem like this.
Old Jan 17, 2012 | 11:38 AM
  #29
cereal's Avatar
cereal
No point paying the dealer to do the work then. Look elsewhere for a more reasonable labor rate. Usually you can find a good independent BMW shop that would love your business and will be cheaper too. No point paying MINI to fix something that shouldn't be a problem.
NYMADMINI
Dec 14, 2016 02:33 PM
gar56
Nov 15, 2016 06:41 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Adam Bradbury
Sep 28, 2015 04:15 PM
EVMini
Sep 28, 2015 10:20 AM
