R56 RE: R56 Oil Hose for Turbo
Old Dec 17, 2011 | 05:09 PM
btsan's Avatar
btsan
Hi all,
I just found out that hose on top of my turbo is bad, and a lot of oil around turbo... Have anyone tried to change this hose themselves?
Is this a common problem?
Thanks in advance,
Old Dec 17, 2011 | 10:17 PM
M0535's Avatar
M0535
I just had that problem. If your car is still under warranty, then your dealer should replace it for free; especially since oil + hot turbo could lead to some bad things...
There are several threads on it already:
https://www.northamericanmotoring.co...pipe-leak.html
img, #cubbies-overlay{ -moz-transition-property: margin, box-shadow, z-index; -moz-transition-duration: 0.1s; -webkit-transition-property: margin, box-shadow, z-index; -webkit-transition-duration: 0.1s; } .cubbies-selected{ z-index: 9999; box-shadow: 3px 3px 8px -1px blue !important; cursor: pointer !important; margin: -3px 3px 3px -3px; } .cubbies-selected:active{ box-shadow: 2px 2px 5px -1px darkblue !important; margin: -1px 1px 1px -1px; } #cubbies-overlay{ position: fixed; z-index: 9999; bottom: 30px; left: 30px; box-shadow: 0 2px 3px rgba(0,0,0,0.8); border: none; } #cubbies-overlay:hover{ box-shadow: 0 2px 3px rgb(0,0,0); }
Old Dec 18, 2011 | 06:43 AM
countryboyshane's Avatar
countryboyshane
I've hard about it before. S**t happens sometimes.
I'm assuming you're still under warranty. To fix it you'll have to place the front end in "service mode" and then basically start dissecting the exhaust system. The exhaust manifold will need to come off to get access to the turbo oil feed connection on the engine block. Should be a fun adventure! Don't forget to buy new banjo bolts and copper seals :-)
Old Dec 18, 2011 | 09:18 AM
btsan's Avatar
btsan
Wow!
I heard it was as simple as replacing the oil hose and the heat shield.
Dang, I should get a hold of the guy at the dealer who told me this...
Old Dec 18, 2011 | 04:33 PM
btsan's Avatar
btsan
No more warranty, unfortunately.
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
tr3y003
Oct 22, 2015 10:48 AM
Lex2008
Aug 16, 2015 08:33 PM
