R56 Valve tap?
Old Oct 28, 2011 | 07:00 AM
shorenetworks's Avatar
shorenetworks
Valve tap?
hello all
On my 2011 Justa 6 speed manual I heard rpm based valve tapping on the right hand side ( from inside the car) during a cold start when I left work in the evening.
Once the motor warmed up it went away?
Also happened again this morning should I be concerned? is it normal?
Old Oct 28, 2011 | 09:56 AM
proximo's Avatar
proximo
This could be just about anything. I've heard a bad alternator bed cause sounds like valve taps. Look at the belts to see if any have been damaged or have extra rubber. The other issue I can think of is the valve sticking. If dirt gets into the lifter, it would cause a gap and the tap is created when the lifter hits the stem. This can be cured with a flush (done at your next oil change). Products like Mega Power flush and the like you can do yourself -- but be sure to read on which brands actually protect the engine and not harm the engine (the "snake oil" products).
Hopefully this helps.
Old Oct 28, 2011 | 10:34 AM
pheatton's Avatar
pheatton
Originally Posted by shorenetworks
hello all
On the 2011 N18 engine there is a strange noise upon start-up. This is caused by the waste gate being fully opened to help warm up the cat and other engine components. There is also a very distinct sound that can be mistaken for valve tap, this would be the Direct Injection system.
I would still drop by the dealer and have them listen just to be sure. My concern was the waste gate open.
Old Oct 28, 2011 | 10:41 AM
clutchless's Avatar
clutchless
Carbon build up on the valves can sound like valve tap. However you probably have too few miles for that to occur. I agree with pheatton, ask the dealer to check it out. That is what the warranty is for.
Old Oct 28, 2011 | 11:59 AM
trwxxa's Avatar
trwxxa
It's normal. We had the same concern when we got my better-half's 2010 Justa, and took it back to the dealer so they could have a listen. My MINI does it too.
elverado
Jan 18, 2022 02:51 AM
schwac2
Oct 17, 2015 06:03 AM
Fordgt4
Oct 10, 2015 10:42 AM
Nicefeet
Sep 24, 2015 06:53 PM
Sep 2, 2015 09:05 AM
