R56 Drilling holes in the body of my Mini.
I want to mount a iPad in my Mini. Right now the best option for this is to drill 2 holes into the drivetrain tunnel (close to the shifter). Using a RAM Mount B Connector and than RAM Mount Ipad Mount.
Is this a good or bad idea? I have looked under the car and seen pictures and there does not appear to be much in the tunnel in that area. I do realize I need to remove the heat shield....
Should I be concerned?
If it does not interfere with anything below, and that's the location you like, I would use stainless screws and coat them with RTV sealant. Also take pic's for anyone else who may want to do this. Good luck.
Sounds like your best option. I don't know why you would want to remove the heat shield if you don't have to.
the center console is made out of plastic and I would have to drill holes into that as well. Its not as sturdy and there is not a good mount point.
I have thought about using a PROclip attached to the centerline... but that too is a little flimsy.
molala
Oct 2, 2015 01:53 PM
mimaal
Sep 4, 2015 09:09 AM
minipopkart
Aug 13, 2015 05:22 AM
