R56 Oil pan heater
Simple fact is, moisture is present in CAR engines due to the type of combustion...many turbo-prop and piston motors on planes I fly have had "tannis" pad heaters, usually on the pan and the gearbox...(when/if present).
In a car, with short trips, and being liquid cooled motors may fail to reach "normal" operating temps...allowing moisture to build up...even a short hop in a plane in rather extreme conditions will result in "normal" temps...and be professional matained....
Lol...on "real men" not using blankets and block heaters...I guess you never flew Garret/honeywell motors...below freezing we used blankets, block heaters, intake/exaust plugs and would often have a/c genorators parked on ramps at locations we would overnight if we could not get mains power (we carried about 100+ of extention cords and preplanned our parking with the FBO so we could plug in when possible)....GPU or not...different story with a PT6...great starting in the cold!!
Anyway even on a short run your crackcase oil will get hot enough to force all moisture out the top, through the PVC valve. (i'm talking moisture due to condensation no moisture due to a head gasket leak)
R50/53 Mystery piece in oil pan
Darksilver06
Sep 2, 2015 10:47 AM
Sep 2, 2015 09:05 AM
