R56 anyone change their transmission fluid yet (R56)?
Old Nov 25, 2014 | 08:21 AM
  #76
afadeev's Avatar
afadeev
Originally Posted by broncobuddha
Thread revival.
I thought the two types of MTF weights were to be used in Non-LSD vs LSD cars. (I can't remember which is supposed to go with which)
How would I tell if I have LSD? (aside from jacking it up and slowly spinning the front tire?)
Enter last 7 characters of you VIN into the following list, and observe the options that were build for the car from the factory. Optional LSD will, or will not be, on that list:
http://www.bmwarchive.org/vin/bmw-vin-decoder.html
a
Old Nov 25, 2014 | 08:26 AM
  #77
broncobuddha's Avatar
broncobuddha
I've actually done that. Nothing listed.
Anyon know what the code for it is?
And do you use the thicker weight for non LSD?
Old Nov 25, 2014 | 01:27 PM
  #78
v10climber's Avatar
v10climber
Pretty sure it doesn't matter. The OEM LSD is a gear-based one so it uses whatever goes in the mini trans normally.
Sent from my DROID RAZR HD using NAMotoring
Old Nov 26, 2014 | 04:19 AM
  #79
tsa1's Avatar
tsa1
My S has 114k miles. Don't know if it was changed in the past. Should I change mine? Transmission runs fine, not as smooth as my gf's 2012 justa with 40k miles, but no slippage or major issues. Fluid exchange or drop the pan?
Old Nov 26, 2014 | 05:10 AM
  #80
v10climber's Avatar
v10climber
Is it a manual trans? I certainly would change the trans fluid at 114k miles. The manual trans on these doesn't really have a "pan". Just use the drain and fill plugs and make sure the car is level when you're filling it back up.
09R56
Nov 16, 2022 10:49 AM
sprp85
Aug 22, 2015 06:16 AM
Lex2008
Aug 16, 2015 08:33 PM
FLYM1N1
Aug 16, 2015 01:17 PM
