R56 Exhaust Help.
Old Jul 4, 2009 | 09:53 AM
drewstermalloy's Avatar
drewstermalloy
Exhaust Help.
Hey guys, I need your help again.. I'm in the process of putting my short shifter in, and I need to take the exhaust system off. I haven't had a problem taking any of it off until I got to this part. Can someone tell me how the heck I get this off without breaking anything?? Any help would be appreciated.
Thanks!!
Old Jul 4, 2009 | 12:39 PM
phxsteele's Avatar
phxsteele
pick one side or the other. I usually do the black side. It is slicker. You can insert a small screwdriver in the hole to help remove it. Be careful though they can rip. There should be a total of 4 you have to remove 2 in the middle and 2 at the rear. The 2 at the rear have a fabric reinforcement that can be slid to the side to give you a little more wiggle room.
Old Jul 4, 2009 | 12:49 PM
old81's Avatar
old81
M6
Hit the rubber hanger with a good spray lube, use a screwdriver with a long handle to pry it off.
If your MINI is newer, should not be a problem, did this on my 07 a few weeks ago, on and off no problem.
Old Jul 5, 2009 | 11:16 AM
drewstermalloy
Awesome, thanks guys! I never got a chance to try it yesterday, planning on doing it a little later today. Mine's an '08, hopefully I won't have too much trouble.
Old Jul 5, 2009 | 02:43 PM
ghosthound's Avatar
ghosthound
yeah, i had a ton of trouble with that when i installed the shifter as well. ended up looking around online and found out that a few spurts of silicon lube will let that sucker slide off fairly easily.
embiggenedmini
Oct 15, 2015 12:36 PM
MasterShaftner
Sep 4, 2015 03:52 PM
Sep 3, 2015 10:29 AM
buckeye_hunter
Sep 2, 2015 01:24 PM
Sep 2, 2015 09:05 AM
