R56 Auto transmission MCS not as fun?
I'd say if you know how to drive with paddle shifters you can drive the MCS faster than the manual. The delay between gears is less than when you manually shift. You simply don't have to depress the clutch pedal and then shift. I drive 100% with paddle shifters and it's working fine.
I get the same "connection" feel as if I had the manual.
remember the JCW kit changes everything, most specifically the shift points, and it's a rush...
Is it available yet? I beleive the exhaust mount points (and the exhaust in general) was a complete redesign.
I just picked up my Zuggy last weekend. She has an auto tranny with paddles. I very quickly discovered a little trick.
If you leave the gear shift in "D" and use the paddles, the tranny will automatically go back to "auto" within a few seconds of using the paddles.
HOWEVER, if you move the shifter from "D" into the SPORT Steptronic position (I'm not talking about the Sport Button), the tranny will remain in a Manual position so you can use the paddles as much as you like. The paddles are especially helpful for highway passing and downshifting, saving your brakes.
The Auto S gives you the best of both worlds.
Good luck!
Good luck!
I am in a loaner again today. Its an auto Just-A-Cooper. Sorry to tell you the car is a real dud for me. There is absolutely NOTHING thrilling about driving it. It makes a very nice commuter car though.
To the OP, go and test drive all the cars. That is what I did. That is THE best way to make up your mind. Maybe the dealer will let you take a manual and then an auto for an extended ride. That should really help you decide.
Personally, after driving automatic on a couple of my cars, I would never buy another without a manual. That being said, the steptronic in the Cooper is a very nice transmission overall, but I would never want to see the repair bills if something were to break. Just too complicated. In the end, it's what you want, and nothing else. If you are happy with just an automatic and you can live with that, fine. Go for it. Have fun! If you need to feel a connection to the car and you like the simplicity and time proven design of the manual, go for it. This thread is pointless. It's all about user preference, and not about true facts.
I get the same feeling all the way around. But those with JCW-fitted MCSa's that are pulling low-mid 14 second standing quarter mile times at the track dont use the stick or pads, they put it in D (Sport mode on, DSC off), left foot brake, rev to 1500-2K, let go, and allow the car shift itself...
Not saying it isn't solid, just saying it will never be as easy to repair as a manual tran. In the long run, what is going to cost more, repairs on a manual or repairs on the steptronic. Think about it.
Also... I'm confident that there will be more rebuild options available for these trannies in the next few years... starting to be enough steptronic-type trannies on the road, it's inevitable that someone makes a good business out of cost-effective rebuilds...
At this point.... no one has a clue, because we don't have enough years on them... but YOU think about it... search the forums and find how many Aisin 6 speeds have failed here (I've heard of NONE) - and compare with the number (and cost) of clutch and flywheel and even manual tranny issues that have been reported here. Factor for the ratio of manuals to autos in the market (granted - there are more manuals out there)... and you'll still see that, at this point... the manuals and related mechanicals are costing way more to keep on the road...
I get your argument - really, I do. And I understand how it applies in general. But it doesn't match the reality of posting history on this forum.
Google:
transmission fail site:northamericanmotoring.com
clutch fail site:northamericanmotoring.com
etc.
Eliminate the CVT issues (which are many, but aren't what we're talking about here) and you'll find the VAST majority concern manual transmissions.... I would wager that, to date, the total out of pocket costs spent on MINI manual trannies and clutches is 20x the total out of pocket spent on MINI Aisin 6 speed automatics. ...
Google:
etc.
Google:
etc.
Google:
etc.
remember it's not so much tranny vs. tranny as it is the two weak links in the MINI manual setup: LuK clutch and LuK DM flywheel, both of which have goads of defective documentation--including two defective clutches and flywheels on my R53 in the first 25K miles. even my Toyota mechanic, who also works on BMWs, will do his best to talk his customers out of LuK clutch and flywheel components (he swears by Aisin), and I dont know many track and auto-X freaks that are OK with that gimpy plastic throwout bearing within their oem clutch setups--therefore they swap out to something more h/d. Plus Ive been to quite a few stock auto-X events where the foul stench of toasted LuK clutches wafts thru the air, and the auto guys are kicked back, laughing out loud, not only over their superior lap times, but that they're able to actually motor, not tow, their cars home...
I chose to get a MCS with auto transmission, simply because of the aggravation of driving a stick in Tokyo. It's stop-and-go hell.
Also, I've been raised in a country where the handle is on the left side of the car, been driving manual cars exclusively there and I still believe I prefer manual, but ever since I moved here and everything is on the wrong side, I can't get my brain (or my body) to smoothly shift through gears with my left hand ;-)
The DS mode of the auto transmission is a lot of fun with the paddles when the streets are empty, and when I'm stuck in traffic there's one less thing to **** me off. Best of both worlds !!
