R56 Speedometer Accuracy
Old Sep 6, 2009 | 08:26 PM
  #51
Shoof's Avatar
Shoof
My '07 VW GTI reads 70mph when I'm really going 65...
Old Sep 6, 2009 | 11:58 PM
  #52
Pinky Demon's Avatar
Pinky Demon
It isn't exclusive to Minis either. My Ford F Series Super Duty is off by 3 as well. Checked by a ScanGauge II.
Old Sep 7, 2009 | 11:19 PM
  #53
Benibiker's Avatar
Benibiker
I never look at the speedo...
Old Sep 8, 2009 | 04:47 AM
  #54
schatzy62's Avatar
schatzy62
Originally Posted by MINIdave
I'm not buying this German/European law thing, I'd like to see some proof on that. Reason is, I've owned several Audis and Porsches and Jaguars over the years including our current '04 Audi allroad, all of which have been spot on.
In fact, my two MINI's are the only cars I've ever owned that had a built in speedo error.
Here are some links for you to look at.
http://www.publications.parliament.u...t/10312w01.htm Scroll down to the part called Speedometer Accuracy.
http://en.wikipedia.org/wiki/Speedometer#cite_note-3 Scroll down to the parts about error. international agreements, Australia and England.
http://www.unece.org/trans/main/wp29...gs/r039r1e.pdf and in this one scroll down to section 5 Specifications. and SPecifically read Section 5.3 which gives the exact tolerances.
What every one here has stated about the speedometer reading high by law is very correct.
Old Sep 8, 2009 | 11:48 AM
  #55
torobud's Avatar
torobud
Originally Posted by Robin Casady
There may be variation in speedometer accuracy from one unit to another. In your case, you seem to have gotten one that is fairly accurate.
Out of curiosity, what wheels and tires are you running?
Apparently I am the oddball with the almost accurate speedo...
Stock 17" Crownspokes and Continental A/S
Old Sep 8, 2009 | 12:01 PM
  #56
jessicaledw's Avatar
jessicaledw
So, I accidentally stumbled upon one of those radar speed check thingies, and yes that is the technical term. You know, the ones that you pass by a sensor that you can't even see and your speed flashes on the screen to make you aware of your speed. Anyway, I had felt after 3500 miles with my Mini that it was probably dead on, maybe 1 mph too fast, but still accurate. Ummm... I was wrong, way wrong. My speed is off by 3 mph, which isn't huge, but I regularly go under the speed limit, which is 30, in my area because it is 100% residential and there are lots of kids around. I never realized that by going 28 or 27, I was actually going only 25 or 24. No wonder people would illegally drive around me when I was turning into my neighborhood. Well, I guess that I no longer need to talk to the local PD about my speed.
PS: I'm going to have my dad drive his MCS through it to see if his speed is as far off as he thinks it is.
Old Sep 8, 2009 | 06:35 PM
  #57
miniclubman's Avatar
miniclubman
Originally Posted by lacynpiper
PS: from what little I know about GPS ( and I could be completely incorrect on this) the speed that it gives you can also be inaccurate due to the distance between your GPS and the satellite.
It's actually the distance between your vehicle and the satellites that's being measured.
GPS satellites all send out a perfectly synchronized signal, but that signal gets to your receiver at different times from different satellites depending on how far they are from your vehicle. This time discrepency enables the GPS receive to calculate your position. Your position change over time determines your speed.
Interesting fact: The atomic clocks on the satellites get out of sync with the ground based master atomic clock, and they must be corrected on a regular basis. Why? Relativity! Thanks to A.E., we can correct for that.
Old Sep 8, 2009 | 08:12 PM
  #58
Dwight Walhood's Avatar
Dwight Walhood
My SA said that BMW purposely sets their speedometers to read 6-10% over actual speed. Apparently, all manufactures do this as they could get in major legal trouble if they made one read below actual speed. Makes sense. He also said the odometers were dead on for the same reason. BTW, if he's right, it will be the first time in the +1.5yrs I've had my MCS!
Old Sep 9, 2009 | 10:02 PM
  #59
k3v1n's Avatar
k3v1n
The one in my 5-series is way off. You'd be going 80 and it will actually be about 73. It gets more inaccurate the faster you drive. My VWs speedo is almost dead-on. Maybe 1mph off.
Old Sep 11, 2009 | 10:05 AM
  #60
bumbles44's Avatar
bumbles44
Tested it last night for first time, seems to run 4 mph faster at highway speeds as compared to my GPS, and with 3 others cars the GPS has always matched the speedo -- also seems to run about 2-3 mph faster than GPS at 25-30 mph.
Old Sep 11, 2009 | 11:47 AM
  #61
pilotart's Avatar
pilotart
It will generally be a consistant percentage of error at all speeds.
Yours looks like +10% which makes correction easy (30=27, 50=45, 70=63, etc.).
Old Sep 15, 2009 | 02:31 PM
  #62
fishbert's Avatar
fishbert
I used to think this as well, before being corrected in these forums by someone else.
GPS units don't measure your speed by comparing position readings, they measure speed by way of red/blue shift in the signal frequency. It makes for a much more accurate measurement than position sample differentials.
Old Jan 4, 2010 | 05:59 PM
  #63
trwxxa's Avatar
trwxxa
Reviving an old thread...
Our little family has now had 3 MINI Coopers -- an '06 Cooper (traded-in), and now 2, 2010 Coopers). Every one of them has a speedometer error that seems to be a combination of a fixed error and a percentage error. The fixed errors are between 2 and 3 mph, and the percentage error is about 2%. Only the 2% error shows up in the odometer.
I see the point of the fixed inaccuracy (European standards), and I have a theory about the percentage error. Our Coopers have the smallest tires available from MINI (175/65R15). They are almost exacly 2% smaller than the largest tires you can get through MINI (205/40R18). Rather than have different programming for each tire size, the manufacturer can just program the ECM for the largest stock tire they offer, and they'll still be within an acceptable error range for the rest.
Just a theory.
It sucks that my odometer is reading 2% too high. That means my warranty will run out at an actual mileage of 49,000.
Old Jan 4, 2010 | 06:06 PM
  #64
JamesHunt's Avatar
JamesHunt
my r56 with 205/45/17 (largest tire mini offers from factory) was off 3%+ always indicated 100 when gps indicated 96/97.
Old Jan 4, 2010 | 07:11 PM
  #65
sequence's Avatar
sequence
My MCS generally indicates about 4 mph faster than it's actually travelling, and that's funny about the faster the speed possibly the more inaccurate it is. last summer I was on an 80 mph stretch of I-15 south of Provo Utah, when I get radar-ed by a state trooper in Charger sitting in the shade under an overpass. The second my detector went off I checked the digital speedo, it said 89-- and the cop did nothing.
And Utah troopers usually dont cut one that much slack.
Old Jan 4, 2010 | 08:14 PM
  #66
Dwight Walhood
The error factor in the speedo is a percentage of the indicated speed, not a fixed mph. On my MCS, it's +10%. Almost all cars made in/for the EU have speedos set to read 7-10% fast. Big time legal trouble if they don't. If it said you were doing 89, you were probably going ~80. BTW, my odometer is dead on and most likely due to the same EU regs.
Old Jan 5, 2010 | 05:11 AM
  #67
Shoof's Avatar
Shoof
My MCS generally indicates about 4 mph faster than it's actually travelling.
I've noticed the same thing in my car. Driving, say 65mph, my portable GPS reads that I'm going 61. Doesn't surprise me..
Old Jan 5, 2010 | 09:06 AM
  #68
Xeraux's Avatar
Xeraux
Yep. That's been my experience as well. The speedo indicates about 4 mph faster than my Garmin GPSMap478 indicates.
Old Jan 5, 2010 | 07:36 PM
  #69
miniclubman
According to this explanation from an educational text created by the jet propulsion laboratory / nasa, it's the time shift that's measured:http://http://scign.jpl.nasa.gov/learn/gps2.htm
Also, TomTom, which should know a thing or two about GPS, has a similar explanation: http://http://www.tomtom.com/howdoes...D=2&Language=1
Of course, they may both be wrong. I would welcome your citation for the red-shift measurement explanation.
Old Jan 5, 2010 | 08:14 PM
  #70
Gerarddm's Avatar
Gerarddm
Is there no way of inserting some kind of rheostat into a circuit so you can tune your speedo to be accurate?
Old Jan 6, 2010 | 05:08 AM
  #71
miniemee's Avatar
miniemee
When I ran 205 45 r17's, the speedo error was about 2 percent. However, switching to 215 45 r17's dropped the error to 1 percent or less.
Old Jan 6, 2010 | 06:11 AM
  #72
schatzy62's Avatar
schatzy62
In a word NO. This si controlled digitally so a rheostat would not do the trick. As for the error it changes as the tires wear and the difference between new tires and fully used tires is between 1.6 and 1.8 percent for most tire sizes.
Also switching brands of tire or even different models of tires from the same manufacturer will change the error as much as two percent.
For example: for a 205-45/17
Dunlop SP Sport 01 DSST (OEM) runs 853 Revs per mile
Bridgestone Blizzak Snow Tire runs 859 revs per mile
so if we divide 853 by 859 we come up with the percentage of difference.
853/895= .993015 or almost 1 full percent change.
so now if we change from one tire size to another say 17" summer to 16" winter the change can be even more or in some cases less depending on make, model, and size.
Measuring off the ODBII port seems to give the closest reading but can still be off by some amount especially when changing tires.
BTW the ODBII and the Speedo in most cases are off by 2-3 MPH. This is built in to make the cars meet European laws as in the links in post #54 of this thread.
Old Jan 6, 2010 | 12:47 PM
  #73
trwxxa's Avatar
trwxxa
The same tire mounted on different width wheels will also cause a variation in the tire's diameter. The specifications of a particular tire will list the tire's diameter, and on what width rim that measurement was made.
My speedo has both kinds of errors -- the built-in 2-3 mph error, and a percentage error caused by tire size. Some 185/65R15s would eliminate the latter.
Old Jan 6, 2010 | 03:06 PM
  #74
ran-o-matic's Avatar
ran-o-matic
You might want to fixify you links - too many http://. Neither one seems to says anything about measuring speed. These are explanations of position fixes. GPS receivers really do use phase shift to measure speed, not position change over time. Position change over time would always over estimate speed with GPS position fixes because of the associated position errors, but the phase detection is VERY accurate. It has to be.
Old Jan 7, 2010 | 03:41 PM
  #75
miniclubman
Citation? ... I'd be very interested in reading how the process you describe works.
Also, GPS position is accurate to within a few meters. The government removed the deliberate inaccuracy in GPS years ago, everyone now can get true readings.
