R56 The "Cold Start" issues, have they been fixed?
My '09 MCS clatters like hell, but the noise is there all the time. does anyone know what year the engines went to direct injection? My guess is that clatter is generated by the direct injectors firing, kind of like a diesel.
As per my other post, 09 JCW at 5000 miles. The noise was on third start with no warm up with wash. So last time i moved out of shop and washed then on next-ed start ran car tile hot, let set for about one hour then start and no noise.
Have not had noise on first start, the two times were after starts that did not get the car hot, so i will make sure that the car is warm before shutdown on second run.
Zarote
If your 2009 MCS is clattering all the time, I'd definitely take it to the dealer. As noted in posts below, mine has only done it once. The rest of the time it sounds great...very smooth sound.
Oldsbear
To you and all those who are interested in this subject, there are two very informative threads on the subject (one of them is a sticky at the top of the topic page).
You can find these discussions at
North American Motoring > 2nd Generation MINIs
The sticky is titled "Cold Start Issues Database" and the thread is titled "Cold Start Chatter". The latter has an explanation which sounds both plausible and consistent with the symptoms commonly being experienced. It has to do with the use of an electric oil pump.
Last edited by corcoranwtnet; Oct 9, 2008 at 01:05 PM. Reason: insert an omitted word
I have had the same experience after washing my 07 MCSm. Something else may be involved -- moving the car a very short distance and then shutting off the engine. Next start: clatter.
From another thread:
Originally Posted by corcoranwtnet
My 2009 MCS-a was eight days old yesterday (276) miles. My wife and I both noticed the clattering (diesel-like) when starting it. . . .
I had done that the previous day on two occasions, prior to the clatter yesterday (i.e., I had started the car, moved it forward or back 3-5 feet, then turned off the ignition. It was on no more than 30 seconds each time.)
Sounds very plausible that the noise could be associated with turning off the engine before it has had a chance to warm the oil, then turning it on again later.
Reply from Oldsbear:
Correlation here. Yesterday I moved my 07 MCSm 50 feet from where I was doing some home repairs, and I got the clatter next time I started. I hadn't heard it since June.
Now if we only knew what that meant . . .
MINI USA, would you please clue us in?
How something like this fails to get noticed in basic testing is beyond me. So I'm not holding my breath for a recall even though there probably should be one.
alistaircookie
Oct 8, 2015 10:52 AM
minipopkart
Aug 13, 2015 05:22 AM
