R56 Quick Question Centre Armrest installation
Old Aug 19, 2008 | 05:15 PM
Lin's Avatar
Lin
Anyone know what size that Thorx Socket is for the Seat Bolts? Install looks fairly straight forward, but would probably go easier if I had the right size Thorx socket.
Thanks!
Old Aug 19, 2008 | 05:47 PM
blackdelight's Avatar
blackdelight
Here's a link to the minimania site that says T-40
http://new.minimania.com/web/Item/G2.../InvDetail.cfm
Old Aug 19, 2008 | 07:16 PM
pilotart's Avatar
pilotart
Yes, T-40 and you only need to loosen the front ones, but not before removing the rear ones, as the raised front torx can prevent seat from sliding forward to access rear Torx Bolt. This is reverse of the order in how-to link.
Also notice that the raise/lower pump also moves seat forward/back a little, so use this to advantage for Torx Bolt Access.
Old Aug 20, 2008 | 04:54 AM
Lin's Avatar
Lin
Thanks for the responses ... she goes under the wrench tonight.
W0TM8
Dec 19, 2019 07:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
mini yellow-haa!
Aug 13, 2015 11:18 AM
flredmini
Aug 12, 2015 06:35 PM
