R56 Sunroof/Moonroof Measurements?
Old Apr 1, 2008 | 12:53 PM
caulyne's Avatar
caulyne
I have searched and searched and can't seem to find the measurements for the R56 sunroof/moonroof.
Anyone wanna take a tape measure out and get me the interior measurements so that I can figure out if one possible fix will work for me and the baby on our three hour drive home across the Arizona desert in two weeks? heheheh Sunburned 4 month olds aren't much fun!
I have some shades that might be a good temp fix for the sunroof before tinting/roof graphic time comes. I just want to know if they'll work.
Old Apr 2, 2008 | 10:20 AM
jimmiejo's Avatar
jimmiejo
24 3/4 X 17 1/2 inches. Front and back. The fold up sun shields that are spring loaded work perfect. There is enough tension to stay in place. I have two sets from some promotion, but sure you can find them somewhere. Each one is just a little larger than the opening and pop into place, just don't forget and try to open the sunroof with them in there or it could cause a problem.
Old Apr 2, 2008 | 10:21 AM
caulyne's Avatar
caulyne
Thank you! You're a rockstar!
Old Sep 8, 2010 | 01:42 PM
JdsMNI's Avatar
JdsMNI
Hi caulyne I have installed the ZippeeShade (it is springloaded) in the front & rear sunroofs. It comes with both in the package.
I purchased it from WMW.
It seems to really work. I also had tint put on before buying the shades. The tint did help some. But is a lot better with the shades.
Later........... JD
Old Sep 8, 2010 | 01:54 PM
onefish2's Avatar
onefish2
Just an FYI here. You can not get sun burned through a glass sunroof nor the windows of your car or any window for that matter. THE UV rays from the sun that cause you to get a sun burn do not penetrate the glass.
Old Sep 8, 2010 | 03:02 PM
JdsMNI's Avatar
JdsMNI
Hi onefish2
I was just telling caulyne about the Zippee Shade. I installed it just to keep the heat out of the MINI on very hot days.
The tint did help some but not enough. Thanks for your replly...... JD
Joeygonz
Oct 4, 2015 09:25 PM
simron
Sep 23, 2015 10:02 PM
Jolio
Factory JCW Talk (2009+)
Sep 17, 2015 09:23 PM
Sep 16, 2015 02:01 PM
Sep 16, 2015 01:59 PM
