R56 My Service Tech recommended changing the oil often
And I am not arguing for the sake of arguing. In nearly every post, I gave additional information or references. I did not stand on a tree stump and say "A3/B5 is the only choice because that is what the MINI bottle has on it". My posts provide someone reading them with information on which to make their own judgement about what they may or may not want to do.
Additionally, I am an ex-racer (motorcycle) myself. And some teams or privateers (myself) do not rebuild their engines every few hours. I ran the same engine for an entire season (less the top end for a bent valve). I didn't use anything but dyno motorcycle oil and my engine regularly saw 12000-13500 rpms. So, while some teams do, some teams don't.
What I am going to do, is purchase a readily available high performance synthetic (probalby the Valvoline synthetic brand in 5W-40 that meets the European rating), change my oil at 1200 miles or so, then change it again at 5000 miles, and continue at that rate for the duration of the ownership of the vehicle. That way, I'll get three freebies from the stealership, and that will be it. Oh, and probably 3 sets of wiper blades.
Everyone is going to do what they want to do, whether you and I beat this to death (more than the bleeding horse carcass can stand) or not.
As a side note...I have been reading quite a bit about the 'shear' rating on these oils. I get the point of what they are saying, but from what I am able to pull from all the data, while their specs are more stringent, I don't really see them as 'better' or more important.
One article I read stated that "oil shear forces are not applied to oil in internal combustion engines" and that "hyphoid gears (differentials) are the only automotive applicaton that test shear ratings".
http://www.bobistheoilguy.com/oilshear.htm
You might want to look at this:
I think both of us have enough of an open mind about this to learn.
I have been going to that site for years. Now comes the bad part.
While I agree and see exactly where some of his tests and conclusions are drawn, I've seen evidence that goes against some of his findings.
Now I may be wrong in this conclusion, but at this point, it's probably moot. But having read the three different papers (including his) I am of the personal (read MINE!!
Having said that....if I use a high quality synthetic that meets or exceeds API SL or SM rating, I will meet or exceed the breakdown that they are looking at if I change my oil at 5k mile intervals.
I am not worried in the slightest that I will damage the engine or not get the 100k-200k plus miles that this engine is capable of.
Thanks for the reply...and have a good one!!!
) opinion that the way they are using shear rating is to measure the break down in viscosity. And in doing so, they are using this measurement in how the long the oil will last with regards to their (MINI's) maintenance schedule.
A suggestion would be to make a simplified sticky that tells you what oils are okay to use and update the first post to include any other finds, although there won't be many beyond what has already been said. Or else, you will be beating this dead horse forever.
Kimolaoha
Jul 5, 2023 01:04 PM
