R56 Suspension Difference Between Cooper and Cooper S?
Old Feb 18, 2008 | 06:39 PM
Prost's Avatar
Prost
Guys,
Is that true that the standard suspension setting of the Copper S is in between the standard Cooper and the Sport Package Cooper S?
If not, are there any difference between the Cooper and Cooper S other then 16" and 17" wheel?
Alan
Old Feb 19, 2008 | 05:07 AM
scabpicker's Avatar
scabpicker
Well, the S has a turbo and a bit more power. LSD is also only available on the S model. Sport Seats, a spoiler, and front fog lights all come standard on the S model, where they are options on the base Cooper. There may be more, but that is what I notice first when looking at the configurator.
I can give you no firm information on the difference between the base and S suspension. I believe there is none. There is the sport suspension, it's available on both models. Beyond that, there is the JCW suspension. I think those are the only suspension differences; the base, sport and JCW. Hope it helps.
Last edited by scabpicker; Feb 19, 2008 at 05:14 AM. Reason: Because I hit submit too soon.
Old Feb 19, 2008 | 07:49 AM
AutoCoarsen's Avatar
AutoCoarsen
The standard suspension on the Cooper and Cooper S are different. They have differerent shocks/struts, springs and sway bars.
The sports suspension (S226A) on the Cooper and Cooper S are the same. They share the same shock/struts, springs and sway bars.
Suspension pieces (control arms, trailing arms, etc.) and bushings are the same on all Cooper and Cooper S cars.
The Cooper S also has larger front brakes. 294mm x 22 mm rotors vs. the Cooper's 280mm x 22mm rotors. They share the same caliper, so I assume you could upgrade the Cooper's brakes easily by buying the Cooper S caliper carriers and rotors. Pads are technically different too. Compound? The rear brakes are identical on both cars.
Old Feb 19, 2008 | 01:43 PM
scabpicker's Avatar
scabpicker
Wow, thank you AutoCoarsen. If you compiled that info yourself from the parts numbers, thankya. If not, where'd you find it already compiled?
Old Feb 19, 2008 | 01:59 PM
Modnar's Avatar
Modnar
Originally Posted by Prost
Guys,
Alan
Technically the Cooper comes standard with 15" wheels, and the S with 16", but those are both bumped up to 16" and 17" respectively with the Sport Package.
Trevor413WC50
Aug 18, 2015 10:38 AM
Aug 12, 2015 01:24 PM
xpunisherx
Aug 10, 2015 10:50 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
