R56 Approved oils for R56 MCS
Old May 28, 2011 | 07:02 AM
  #176
SMOG's Avatar
SMOG
Alliance Member
0-30 Castrol Syntec
I found Castrol 0-30w Syntec European Formula @ Autozone here in Western Washington. It is not inexpensive but since I do a mid cycle oil change at home it saves $$$.
S.
Old May 28, 2011 | 07:41 AM
  #177
MiamiGuitarMan's Avatar
MiamiGuitarMan
Ok so my problems is solved. I did what I should have done from the start and called the nearest Mini dealer which is about 20 minutes away from me. They sell the Mini oil for 6.75/qt and the filter for 12 bucks. Oil change should run me under 50 bucks.
Car's already at 2100 miles so I'll probably be doing the first one somewhere between 3K and 5K.
Old Apr 24, 2012 | 04:22 PM
  #178
fastfour's Avatar
fastfour
S.
I just picked some up at the Autozone in Shoreline for $8.79/qt. I've been changing the oil/filter in between dealer changes. The dealer wants over $11 after tax for the "Mini" oil. No thanks.
Old Apr 24, 2012 | 07:07 PM
  #179
Porthos's Avatar
Porthos
I just put Castrol Edge 0w-30 in my car. Seems to be running good.
Old Apr 24, 2012 | 07:35 PM
  #180
Ch28Kid's Avatar
Ch28Kid
I use Royal Purple 5w30 for 25000 km, so far so good.
Old Sep 6, 2012 | 12:57 PM
  #181
Hank Rearden's Avatar
Hank Rearden
Originally Posted by johne123
As this is mostly a Peugeot engine with BMW adding their valve timing stuff, I don't know that BMW has dealt with the lubrication requirements of this engine to say if an LL-98, LL-01, or the really tight LL-04 is needed.
Also, when BMW and Peugeot say fully synthetic oil they mean Group IV and V oils built up from scratch base stocks. When printing the manual for the US I don't know that BMW NA knows the different between EU law that states for an oil to be synthetic it can't be made from modifying Group III or lower oils that come out of the ground. In the US they can say that. The main difference is the Group III synthetics these days offer as much protection but for not as many miles. Does the ACEA A3/B3 spec deal with oil life or performance over time?
Valvoline, Castrol (expect for German made 0w30), Pennzoil are Group III synthetics.
So it's interesting that the 5w40 Castrol meets A3/B3.
Hmm, the spec linked does mention A3/B3 includes for extended drain intervals, but I haven't looked through the rest of the documents.
As a Peugeot 207 RC owner, I have to blame BMW for all the timing chain issues withs this engine !!
I saw 25 years old engines with better designed timing chain tensioners...
Old Oct 11, 2012 | 12:08 PM
  #182
kyoo's Avatar
kyoo
surprised more people aren't running amsoil here - i think i'd like to do all the maintenance myself on the car
Old Oct 11, 2012 | 12:23 PM
  #183
jkapinos's Avatar
jkapinos
amsoil SSO 0w-30 for me.
Old Oct 11, 2012 | 04:04 PM
  #184
kyoo's Avatar
kyoo
used to run sso 5w30 and 10w30 on the evo, switching to zrod soon
Old Oct 11, 2012 | 05:01 PM
  #185
jkapinos's Avatar
jkapinos
Yes I ran the SSO in my EVO as well. Since then I did an engine build on it and can't use the SSO. So I looked up the MCS on the amsoil site and it suggested the SSO. Since I had a case, that's what I've been using. It's been great so far.
Old Nov 11, 2012 | 03:09 AM
  #186
OhBe1's Avatar
OhBe1
FWIW, $7.45/qt and $13.43/filter at MINI of Annapolis.
Which makes OEM oil almost identical in price to Mobil's recommended Mobil1 0w40 at Advance.
Kimolaoha
Jul 5, 2023 01:04 PM
ShadyCoop
Aug 24, 2015 06:05 AM
Lex2008
Aug 16, 2015 08:33 PM
clintmeister
Aug 12, 2015 11:11 AM
