R56 First and Best Upgrades
Old Jan 7, 2008 | 07:08 PM
  #26
Msteadman's Avatar
Msteadman
Originally Posted by jw34
One of my best upgrades was to go back to the dealer and get the little velcro discs that go under the rubber driver side mat to keep it from slipping.
I need to do this as well. May get the door/weather seals installed at the same time. There aren't velcro discs available for the passenger side, correct?
Old Jan 7, 2008 | 07:30 PM
  #27
lacning74's Avatar
lacning74
Don't have the rubber mats, but my carpet floor mats had velcro discs on both sides unattached the floor. After checking this forum, I just twisted the self tapping screw right into the floor. Keeps the mats well secured. You figure my dealer would have done it for me. I could have gone months without knowing.
Old Jan 7, 2008 | 07:33 PM
  #28
jw34's Avatar
jw34
Correct. Really the passenger side doesn't slip so they probably aren't necessary.
Old Jan 8, 2008 | 03:12 PM
  #29
Augie05's Avatar
Augie05
This is a great thread. Any more suggestions?
Old Jan 8, 2008 | 03:18 PM
  #30
korby's Avatar
korby
Get rid of the dealers license plate holder ! Why give them free advertising ,what did they do for you ?
Old Jan 8, 2008 | 04:06 PM
  #31
jw34's Avatar
jw34
Yes! I amazed at how many cars I see (and lots of high end ones) that keep the tacky dealer plate holder. You have a gorgeous car with a holder that uses type from the dregs of the font world.
Old Jan 8, 2008 | 04:14 PM
  #32
curtis0407's Avatar
curtis0407
jw34 Yes! I amazed at how many cars I see (and lots of high end ones) that keep the tacky dealer plate holder. You have a gorgeous car with a holder that uses type from the dregs of the font world.
+1
Old Jan 9, 2008 | 09:08 PM
  #33
Duke-Nukem-Dan's Avatar
Duke-Nukem-Dan
Wow ya thanks again guys, I've been reading all kinds of stuff and never thought about not being able to see lights. Of all the things that is probably the biggest problem you could have. Thanks!
Old Jan 12, 2008 | 09:12 PM
  #34
BMBULBE's Avatar
BMBULBE
Get rid of the run flat tires. They ride like bricks.
Old Jan 12, 2008 | 09:36 PM
  #35
n1tr0's Avatar
n1tr0
I have some Eibach springs on order for when it arrives, then it'll get a light tint job (still want it to feel fun/bright inside).
tires & wheels come spring (some Rota RB's with either g-force sports or tech 500's)
an ags-r intake so the hoodscoop is a functional piece and eventually a full turbo-back exhaust.
I promised my wife I wouldn't mod our new car after I took my last little hotrod past the point of being street driven... The MCS doesn't have the same hp/torque as my old turbo sprint, but it comes with a warranty for a few years
Old Jan 13, 2008 | 08:01 AM
  #36
jygoalkeeper's Avatar
jygoalkeeper
I added a minidomore trailer hitch receiver so I could add a hitch mounted bike rack.
Old Jan 13, 2008 | 08:24 AM
  #37
chuck r's Avatar
chuck r
Originally Posted by Ryephile
Here are my recommendations for improving the R56 in terms of precise handling and power to weight:
1) A turbo back exhaust...I built my own 'cuz I'm a fabricating nutcase, but ALTA or Milltek's are both good quality. This will gain you about 10 wHP and you'll be able to actually hear the car! On top of that, an aftermarket exhaust will remove about 10 pounds.
2) JIC/Cross Coilovers from RMW. Go from great factory handling to OMG kick-butt handling & lowers the car to give it a MINI look, not an SUV/factory look.
3) ALTA PSRS eccentric spherical bearing front control arm bushings to tighten up that nasty wandering steering.
4) Get a good set of wheels and tires! The R56 loves wide tires; a 17x8 et37-ish with a 235/40-17 will give crazy grip and a more aggressive look...and if you're smart about it, you'll lose some weight from the boat-anchor factory wheels.
5) Toss the rear seats! Nobody's going to squeeze back there anyway, so removing the rear seat backs and bottoms will free up about 40 pounds.
6) Swap out the heavy lead-acid battery with a lightweight Braille or Odyssey battery, saves about 20 pounds.
That should give you some naughty ideas!
Cheers,
Ryan
I like your thinking.
chuck
Old Jan 13, 2008 | 12:56 PM
  #38
Msteadman's Avatar
Msteadman
Sounds sweet! Looking forward to hearing your feedback on the Eibach springs. I'll definitely be adding lowering springs within the next few weeks and they're top on my list right now. Also adding the ALTA turbo back and Rota RB's in gunmetal around that same time What color RB's are you looking at?
Old Jan 13, 2008 | 01:17 PM
  #39
n1tr0's Avatar
n1tr0
I've installed a lot of lowering springs over the years on my own cars & customers, I've generally had better luck with Eibach's over H&R's. Either are going to be an improvement over the stock suv look, but the butt is pretty subjective. Generally speaking, the H&R's will look a bit better/lower, while the Eibach's will offer a better ride (bit firmer, bit taller, less hitting the bumpstops).
I'm torn on the Rota RB's, all silver for the classic lighthearted mini look, or gunmetal centers for the more aggressive look. My wife wants it to look tough, I'm more into rolling down the windows, cranking back the sunroof and laughing my way around the corners.
Old Jan 13, 2008 | 04:19 PM
  #40
Chuck W.'s Avatar
Chuck W.
I bought Mach V springs and non runflat tires prior to taking delievey of the car.
Old Jan 13, 2008 | 04:58 PM
  #41
Msteadman's Avatar
Msteadman
Sounds good. That was my main concerning with lowering. I want to get rid of the ridiculous wheel gap, but we have so little suspension travel already and the roads around me aren't exactly great. So I'd definitely be willing to go with a firmer ride opposed to bottoming out constantly. Also I'll be putting some relatively large wheels/tires on my MINI, so if anything the Eibachs being slightly higher is a good thing.
Well it's for selfish reasons, but I'd say go for the gunmetal! I'm really curious to see how they look a non-DS MINI, as that's the only color I've seen them on thus far. My MINI is PW/B so although I love the RB's in GM, it's kind of a risk. Oh and it's definitely the more aggressive color.
Old Mar 2, 2008 | 11:02 PM
  #42
ASN's Avatar
ASN
if you don't have it, get the ipod hookup! that's something i use every second i'm motoring.
Old Mar 3, 2008 | 09:17 AM
  #43
byhsu's Avatar
byhsu
for me it was the home made cold air intake. I can feel the engine is more flexible, I can stay in 6th gear under 50mph now. More fuel economy too and that sweet blow off valve sound
Old Mar 3, 2008 | 01:10 PM
  #44
steaming79's Avatar
steaming79
VERY 1st thing i got rid of
Old Mar 3, 2008 | 01:35 PM
  #45
dreman's Avatar
dreman
To those that suggested spring upgrade:
Is this something I can do in my garage? Do I need any special tools?
I really like the idea of a CAI, but I am really concerned with voiding the warranty. Maybe I should check with my dealer before I touch this thing.
Old Mar 3, 2008 | 04:17 PM
  #46
ANT818's Avatar
ANT818
get rid of the run flats.
Old Mar 3, 2008 | 04:20 PM
  #47
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
Best upgrades for me are in my sig. If you have a turbo and you actually want to hear it, then get rid of that crappy oem airbox.
would also like the rest of the Alta goodies available.
Some Cross Coilovers would be nice. New wheels, Tires. Vinyl blackout.
Old Mar 3, 2008 | 04:22 PM
  #48
srmach05's Avatar
srmach05
I have yet to receive my MCS, but my first "mod" is definitely going to be a nice clear bra for the front bumper - don't want that pepper white to get chipped during my daily commute on the highway!
molala
Oct 2, 2015 01:53 PM
Sep 10, 2015 10:52 AM
Sep 3, 2015 10:29 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
