R56 A question about the front bumper
Old Dec 23, 2007 | 10:01 AM
uzun's Avatar
uzun
This is a question about the vertical plastic pieces installed underneath the front bumper. These pieces are directly in front of the tires. I think they are called splash guards. I have the JCW aero kit front bumper by the way.
I did a DIY oil change on my car for the first time yesterday. I used ramps to raise the front the car. I noticed that when I drive the car up and down the ramps, the splash guards underneath the front bumper rub against the ramps. I am concerned that this rubbing may cause the plastic pieces to break or cause other damage to the front bumper. So during future oil changes, I would like to remove these plastic pieces first before I put the car on the ramps.
I inspected these pieces to see how they are attached. There is a regular 8 mm screw with a hex head and two other plastic screws with flat circular heads holding them. I can remove the 8mm screw easily. But I don't know how to remove the other two plastic screws with circular heads. They don't have a groove on them so I can't use a screw driver.
Does anyone know how to remove these plastic screws?
Old Dec 23, 2007 | 11:01 AM
djam43's Avatar
djam43
Sounds like you are trying to remove the "push-on /pop off" fasteners that are used throughout the car. If so you need a set of car panel remover tools to do it properly, ( Harbour Freight sells a set of 3 for about $5) you can also use 2 screwdrivers to lift the round top of the fastener and seperate it from its rivet, but you will probably damage it,(like I did). If you do you can purchase a package of them for about $3 in most auto stores.
Old Dec 23, 2007 | 11:05 AM
scott48's Avatar
scott48
Those plastic pieces you're talking about make up the front air dam.....and to remove those plastic fasteners is really simple. Just use a flat head screwdriver to pop out the piece with the flat head in the shape of a circle, and then you can pull the rest out....really simple and you won't damage them, so you can reuse the fasteners.
Old Dec 23, 2007 | 12:58 PM
uzun's Avatar
uzun
Thanks guys! I will see what I can do.
Old Dec 23, 2007 | 08:26 PM
lacning74's Avatar
lacning74
Something like this? I assume the notched ends are for prying up the round top of the fastener?
Old Dec 23, 2007 | 09:01 PM
lacning74's Avatar
lacning74
I decided to try some fancy plier-type removing tool.
FLYM1N1
Aug 15, 2015 11:20 AM
smlzilla
Aug 14, 2015 07:00 PM
JHolland
Aug 13, 2015 10:47 PM
skippermini
Aug 12, 2015 10:05 PM
