R56 Strange Wiring Effect
Old Nov 30, 2007 | 10:56 AM
Loony2N's Avatar
Loony2N
Last Spring I had a car audio place hard wire my Valentine One while they were installing something else. Yesterday, I discovered something weird: When I turned on my rear window defogger, the detector turned off. When I turned the defogger off, the detector went back on. It went through the entire boot-up sequence, so I am confident it actually was de-powered as opposed to experiencing any kind of rf interference. Any ideas? Is there a relay that cuts power to some circuit when the rear defogger is turned on?
Old Nov 30, 2007 | 11:10 AM
djam43's Avatar
djam43
It looks like you will have to find another power source for your detector or live with this condition. Most R56 circuits are monitored electronically for overcurrent conditions, apparently they tapped into the wrong circuit.
Old Nov 30, 2007 | 11:46 AM
Loony2N's Avatar
Loony2N
I figured it was that, since the rear defogger draws huge current.... But, unless it is relayed, it couldn't just be wired to the rear defogger circuit because if power was cut due to overload, it would be cut to the defogger as well as the detector. In this case, the defogger comes on, the detector goes off. Shut off the defogger and the detector comes back on.
Old Nov 30, 2007 | 12:34 PM
GBMINI's Avatar
GBMINI
Maybe the ground for the V1 is to the rear defog; low enough resistance to be a pretty good ground, but no use at all when a supply is sent to it.
Filmy
15
Jun 6, 2023 06:27 AM
dinomaniac
Sep 18, 2018 04:19 AM
Sep 11, 2015 10:32 AM
Sc00terbum
Sep 11, 2015 09:07 AM
Filmy
Sep 7, 2015 08:27 PM
