R56 Ran Out of Gas Again
Old Nov 28, 2007 | 09:05 PM
  #26
ekailee's Avatar
ekailee
Please explain!
Originally Posted by sancochojoe
Same here...I never allow my gas to run that low and it does put a strain on the fuel pump. Might have to change your gas filling habits
Originally Posted by Bhatch
why even run the car that low, it puts unnecessary strain on the fuel pump. I always try to keep 1/2 a tank or more in the car for daily use.
Could either of you explain "Strain" on the fuel pump.
Old Nov 29, 2007 | 11:11 AM
  #27
SomethingNew71's Avatar
SomethingNew71
Don't run it to empty. Problem solved.
Old Nov 29, 2007 | 11:47 AM
  #28
Event-Horizon's Avatar
Event-Horizon
Generally the gasoline is used to cool the fuel pump because it is submerged in it. If the tank is near empty the fuel pump is exposed allowing it to heat up, possibly shorting its life span.
This may not be as big a problem as it was in the past, but some people still feel that keeping the fuel pump submerged is better for it’s operation.
Old Nov 29, 2007 | 12:24 PM
  #29
djam43's Avatar
djam43
The fuel pump probably uses the gasoline to lubricate it , Just like an aeroplane tank, since its immersed in the liquid. getting too low could starve the pump and cause premature failure.
Old Nov 29, 2007 | 12:40 PM
  #30
F13rc3dr4g0n's Avatar
F13rc3dr4g0n
Not short, fun size!
glad i didn't have the problem on my month long trip... on my way home looking for a gas station i ran my gas tank down to 2 and 15 miles left... gas stations are rare on some roads... :(
Old Dec 1, 2007 | 10:36 PM
  #31
ekailee's Avatar
ekailee
Thanks for the explaination on "strain". My son-in-law is a BMW master tech I'll ask him about the premature failure issue.
I took a road trip and ran down to 9 miles left. Filled up the tank with 13.5 gallons in the 13.2 capacity tank!??
Oh well, I don't think I'll let it get down anymore.
Old Dec 1, 2007 | 10:41 PM
  #32
Mrono's Avatar
Mrono
most i've filled up was 13.5, and it was in the red and down to 20miles left.
Old Dec 2, 2007 | 08:26 AM
  #33
rockridge's Avatar
rockridge
I know that the gauge on my is kind of screwed up. With 3 lights out, if I fill the car, it takes about 7 gallons. So it's about 1/2 a tank. I would be nice if there was a calibrate the gauge.
Old Dec 2, 2007 | 08:53 AM
  #34
Crashton's Avatar
Crashton
djam43,You have explained that perfectly. My wife, bless her heart had a very bad habit of running her Audrey A4 on fumes. After 3 years of this just before the lease was up the fuel pump croaked. Thank God it was under warranty. Best of all my wife has learned the lesson I couldn't teach her.
Old Dec 2, 2007 | 11:43 AM
  #35
ScottRiqui's Avatar
ScottRiqui
If the pump is lubricated by the gasoline *passing through it*, totally running out of gas would remove the lubricant and damage the pump, but there's also the theory that the pump is cooled by the gasoline *surrounding* it, in which case, even letting the fuel level get too low (without running out entirely) could damage the pump by uncovering it in the tank.
I've never looked inside a MINI gas tank, though, so I don't know if the pump body itself is actually immersed in the fuel, or how low you'd have to run the tank in order to uncover it.
Old Dec 2, 2007 | 12:14 PM
  #36
Crashton's Avatar
Crashton
Yes it cools it too & you are 100% correct Scott. My wife never ran out, but was always running her A4 on fumes.
Old Dec 2, 2007 | 02:26 PM
  #37
daffodildeb's Avatar
daffodildeb
That's probably because you topped off and there was fuel in the filler neck, which is not part of the tank size computation.
Of course, there is always the possibility that the pump is not calibrated properly.
Old Dec 8, 2007 | 08:02 AM
  #38
nfrntau's Avatar
nfrntau
I took my Mini to 27 miles left to go, one bar. Decided not to push it any further, filled up and it took 13.5
Old Jan 18, 2008 | 08:58 PM
  #39
Benibiker's Avatar
Benibiker
How does running your tank level lower than half a tank put stress on your fuel pump?
Old Jan 18, 2008 | 09:12 PM
  #40
muladesigns1's Avatar
muladesigns1
why would one let there gas tank get that low. all you do is unsettle all the deposits on the bottom of the tank and end up clogging up your filter and or injectors. I always fill mine when it hits a 1/4 tank.
Old Jan 18, 2008 | 09:13 PM
  #41
shokk's Avatar
shokk
7th Gear
Maybe half a tank isn't dangerous, but it helps not to get close to trouble if you want to avoid trouble. One bar is definitely too low for me. If I see two bars left, I'm definitely headed to the nearest gas station.
Old Jan 18, 2008 | 09:21 PM
  #42
muladesigns1
you are correct. most pumps are in the tank so the gasoline can cool them off. they are small though and would require only a couple gallons to submerge them enough to keep them cool. the only time you would do damage to them is if you constantly kept a low tank.
Old Jan 19, 2008 | 06:21 AM
  #43
shokk's Avatar
shokk
7th Gear
So the question then is, how far down into the tank is the pump itself?
Diagrams would help illustrate the issue.
Old Jan 19, 2008 | 08:47 AM
  #44
chuck r's Avatar
chuck r
"Risk Takers" unite. It's these little gambles in life that keep it exciting. Anyone can fill up at a quarter tank. This discussion is about the human personality. Some people go for it some just sit on the sofa and watch it on TV.
Old Jan 19, 2008 | 09:01 AM
  #45
r56mini's Avatar
r56mini
I have not ever seen a linear gas gauge in the cars I have driven. The needle moves slowly when full but it speeds up as it goes down.
Old Jan 19, 2008 | 09:06 AM
  #46
Eric_Rowland's Avatar
Eric_Rowland
I think that's more of a safety cushion, as you never know when you might go for a while with no gas available or no time to fill up.
My reasoning has always been the lower I run the tank, the less amount of time I spend in a gas station, which is not a quality portion of my life.
In my CRX I would often 'challenge' myself to see how far I could go. Fortunately it was light enough that I could push it into the station when I ran out just before entering. At some point I tired of running out of gas and started filling up. I think the moment of change was running out on Christmas on the way to my fiance's house.:impatient
Note that the fuel pump is now pretty noisy, but it's still pumping at 205K/23 years.
Old Jan 19, 2008 | 06:55 PM
  #47
nfrntau's Avatar
nfrntau
I thought I would add this to the discussion. A full tank of gas is like running around with an extra person in the car. At over 8 lbs per gallon, a full tank of gas will be almost 100 lbs. Does it make a difference? Maybe a little bit. My best so far is 36.6 mpg for a complete tank of gas at 70 mph with two persons in the car. (Which the Magellan actually says is 67 mph)
Old Jan 20, 2008 | 10:47 AM
  #48
ScottRiqui's Avatar
ScottRiqui
Actually, it's *water*, not gasoline, that's 8+ pounds per gallon. Gasoline is closer to 6.25 or 6.5 pounds per gallon.
Surprisingly, the weight of your car isn't going to have much effect on your fuel economy *on long highway drives*. It will make a difference around town, where you're constantly changing speed, but even then, the gas in your tank is a fairly small fraction of the total weight of the car + driver.
Old Jan 20, 2008 | 02:21 PM
  #49
muladesigns1
As I see it NO GAS = NO JOURNEY
Old Jan 20, 2008 | 02:23 PM
  #50
muladesigns1
youll make up for the longer duration inbetween stations with a nice week long stay in the dealers bay while your getting you injectors swapped out at over a grand!
Ill take the 1/4 tank rule and motor on!
