R56 Underpowered Heater?
Old Nov 24, 2007 | 07:34 AM
  #26
Minerva Louise's Avatar
Minerva Louise
Originally Posted by carla99
I have a manual hvac system and have noticed that it does take a long time to cool and heat. Just tonight (32 degrees outside) it took about 13-15 minutes before I really started to feel some heat and that was on the hottest setting (with no snowflake depressed). Maybe my system is faulty? Anyone else with a manual setting having this issue of slow response time?
You might have a faulty thermostat. This device is not so much to do with the climate control system, but rather is a part of the cooling system of the engine itself. Generally, the engine has the larger part of the cooling system closed when the engine is cold. This allows the engine to more rapidly reach otimal operating temperature. The thermostat opens when the engine gets nicely warm and at that point the coolant flows all through the cooling system of the car (radiator). If the thermostat is faulty, it will stay in the "open" position. The car will take a loooooooooooooooooooooonnnnnnnnnng time to reach optimal operating temperature, if it EVER gets there.
The other thing to try (and by far the easiest and cheapest and this is the first thing to do) When you start your car, do you turn the heat all the way to hot and air to high the minute you get in the car? This can also make the heater take much longer to get hot as well. There is no good reason to blast your ankles with freezing air, so watch your temperature gauge. It will be cold, cold cold, then suddenly will start upward. When it starts getting some heat, only then turn on your heater and see if you have better results. Now, if the temp gauge like NEVER starts upward forever and ever, then that is indicative that you need a new thermostat.
Old Nov 24, 2007 | 09:52 AM
  #27
Super Dave's Avatar
Super Dave
Originally Posted by rustyboy155
Well, by that notion 84º degrees is still about 14 degrees off from your body's temperature, but setting my heat to 84º works pretty well (The air is a LOT hotter than 84º). As others have said, that's not how automatic HVAC systems work. The temperature you set it to is the temperature it tries to maintain, NOT the temperature of the air that comes out (WAY too many people don't know that).
That's why people hate Auto HVAC, because they play with the controls too much and it ends up being more work than manual. Set the temperature, and leave it alone. If the temperature you set is too hot, lower it, if it's too cold, raise it. Too often do I see people get in their car and set the temperature to "High" or "Low".
Sorry, I would NEVER want my car to be 86º+ or 60º- (Both those settings crank the AC to 100% and LEAVE it there. My AC rarely leaves 70º unless the temperature difference is extreme. Sometimes when I get in the car if it's really cold out I'll raise it to 78º until it warms up, then lower it to 70º, if it's really hot out, I'll lower it to 66º until it cools down then raise it back to 70º. There's NO reason to adjust the air temperature 25 times on a 30-40 minute drive. The only reason I change it when I get in the car is to compensate for the systems sluggish response to temperature changes.
Hey Rustyboy - How did you make the "degree" symbol? I have always wondered where that was on my keyboard!
Old Nov 24, 2007 | 10:03 AM
  #28
Robin Casady's Avatar
Robin Casady
The heated seats are nice.
Somewhere I read that the MINI does not use a traditional coolant thermostat. My MCS will take much longer to reach 222 F* (normal running temp) than my Integra. I've actually driven about four miles in the MINI before it reached operating temp. It depends on the kind of driving, and how much load there is.
*I use a ScanGaugeII for coolant temp readout.
Old Nov 24, 2007 | 10:21 AM
  #29
ScottRiqui's Avatar
ScottRiqui
On a Mac, it's Shift-Option-8.
On Windows, hold down the ALT key, type 0176 on the numeric keypad, and then release the ALT key.
Old Nov 24, 2007 | 10:46 AM
  #30
The Meal's Avatar
The Meal
..and from the teach a man to fish department...
Also useful (for other characters, or non-standard characters in URLs when you're trying to link on web forums...):
http://en.wikipedia.org/wiki/Windows_Alt_keycodes
~Neal
Old Nov 24, 2007 | 10:56 AM
  #31
ScottRiqui's Avatar
ScottRiqui
And the Mac version:
http://tlt.psu.edu/suggestions/inter...s/codemac.html
Old Nov 24, 2007 | 11:15 AM
  #32
MotorMouth's Avatar
MotorMouth
No problems with my auto ac - set it to 70 and forget it.
Never use the heater in Hawaii though.
Old Nov 24, 2007 | 08:25 PM
  #33
Super Dave's Avatar
Super Dave
º! Thanks! º
Old Nov 29, 2007 | 07:37 PM
  #34
mattminicoop's Avatar
mattminicoop
I have the auto climate control and there is one thing I don't understand. Now it's cold in the North East, when I turn on the system the AC light (snow flake symbol) comes on. I don't want that, do I? I turn off the AC and it heats up just fine, but why does it turn the AC on in the first place?
Old Nov 29, 2007 | 08:15 PM
  #35
ghosthound's Avatar
ghosthound
*The more you know*
typing that in is harder than just typing out degree though... or at least to me...
i find it funny that you complain about the weak heater... they should just route the hood into the car cuz that thing gets scorching!
Old Nov 30, 2007 | 08:10 AM
  #36
Spectral Glider's Avatar
Spectral Glider
Yeah, I just leave the auto on (without AC) and don't turn it off when I shut the car off. That way, it's ready for heat when I start the car next time. As to why it's set for AC to come on initially, I have no idea. They must think we're all a bunch of hot heads or something.
What I want to know is, can I turn off the ice warning chime that rings whenever it's below 37 or whatever? Thanks for the tip, but trust me, I already know it's cold out.
Old Nov 30, 2007 | 09:47 AM
  #37
djam43's Avatar
djam43
That is normal in most AC systems . That ensures that the slide valve in the AC system gets exercised for a few secs every time you turnon the heater system. Otherwise if you ran the heater all winter and then turned on the AC in the summer, that valve may not budge. The same goes for the reverse-cycle systems in most houses.
Old Dec 16, 2007 | 08:04 AM
  #38
chili_red07's Avatar
chili_red07
To anyone suffering from a "weak" heater: Did you open your hood scoop up? I had mine open and once it got really cold my heat never warmed up. I plugged it back up with the intention of keeping salt/ whatnot out of my engine compartment and voila! Wicked hot heater that is almost instantaneous!
Old Dec 16, 2007 | 08:17 AM
  #39
lacning74's Avatar
lacning74
I find Auto cumbersome on cold days. I have been leaving the temperature on the highest and just adjusting the fan as needed.
Old Dec 16, 2007 | 08:53 AM
  #40
Karthi's Avatar
Karthi
Here's the manual text ....
When the cooling function is on,
the air is cooled, dried, then
reheated according to the temperature
setting.
Depending on the weather, the windshield may
fog over briefly when the engine is started or the
cooling function is switched off. The recirculated-
air mode may is switched on automatically.
The cooling function is automatically switched
on along with the AUTO program. The passenger
compartment can only be cooled while the
engine is running.
As far as the heating/cooling system in the R56, the auto climate control is pretty good ... I've had no problems with it ... I will say that it takes about the same, maybe a little longer than my previous car's auto climate control (03 Acura RSX type-s), but not a significant enough different to complain about.
Old Dec 16, 2007 | 09:06 AM
  #41
Tommy122's Avatar
Tommy122
I have the manual heater. With the outside temp at about 35, I can feel warm air after driving a couple of blocks. In about a mile or so, I have to turn it back. It hasn't been in the 20's here so I can't say how it would work with that outside temp, but I expect it would be about the same.
Old Dec 16, 2007 | 09:08 AM
  #42
Sowellman's Avatar
Sowellman
When I turn on the system the AC light (snow flake symbol) comes on. I don't want that, do I? I turn off the AC and it heats up just fine, but why does it turn the AC on in the first place?
It does seem odd, but an air con paired with a heater is the most effective method of removing interior condensation. It's just that you should be able to turn on the AC at will, not have it come on automatically.
Old Dec 16, 2007 | 09:27 AM
  #43
4xAAA's Avatar
4xAAA
We opted for manual, saved some money. Warm in winter, cool in summer. No gremlins running the program.
Old Dec 16, 2007 | 04:09 PM
  #44
DanF's Avatar
DanF
I have the manual heat and lately it has been below 20F. I have heat within 2 miles with no warmup what so ever. These cars do not have thermostats, the water pump stays off until the water temp is up. If you are having problems with heat your water pump could be running before the water temp gets up to the proper operating temp.
Old Dec 16, 2007 | 04:43 PM
  #45
jggimi's Avatar
jggimi
Originally Posted by DanF
...These cars do not have thermostats...
Huh?
From http://www.google.com/url?sa=t&ct=re...WlVjMqgL-oix8w
Originally Posted by page 14
Integration of numerous functions and components such as the oil dipstick,
the vacuum pump, the high-pressure pump, thermostat housing and
intake silencer serves additionally to meet the great demands made of the
engine package.
Originally Posted by page 15
To save drive power and expedite the warming-up process, coolant is not
circulated until the engine has reached its normal operating temperature.
Then, when it has reached the appropriate temperature, the engine is held
steady at that point by a thermostat masterminded by the engine’s
electronic “brain”, ensuring the most fuel-efficient coolant temperature at
each respective operating point.
Old Dec 16, 2007 | 04:52 PM
  #46
Joey D's Avatar
Joey D
I have the manual heat and a/c controls and I think the heater is worthless. But I have the heated seats so it's not a huge problem.
Old Dec 16, 2007 | 05:48 PM
  #47
Coopaw's Avatar
Coopaw
I set mine to 68° and it seems to heat up pretty quick for me. No complaint here.
Old Dec 16, 2007 | 06:08 PM
  #48
Modnar's Avatar
Modnar
How open did you open it up? All the way, or to the level that they later opened up all of the scoops (just a few holes)?
Old Dec 16, 2007 | 06:14 PM
  #49
chili_red07
all the way. there is one screw that hold the scoop in place. remove it and pull firmly on the scoop and it pops out. once out there are 4 screws that hold the black "mesh" piece. remove them and pull out the piece. reinstall the scoop and you're good to go!
here's the thread: https://www.northamericanmotoring.co...pen+hood+scoop
Old Jan 4, 2008 | 09:25 AM
  #50
jblaw's Avatar
jblaw
Loud Fan
Along the same lines as this, is anyone else's fan pretty loud? I can definitely hear it even if it is on its lowest level.
-Jeff
