R56 Is MINI coolant the same as BMW coolant?
Old Nov 18, 2007 | 03:00 PM
uzun's Avatar
uzun
The reason I ask is because I have some BMW coolant remaining from my previous BMW and I would hate to throw it away. Can I safely use it in my MINI in case I need to add some coolant? The nearest MINI dealer is 160 miles away and I did not get a chance to buy some MINI coolant yet.
Old Nov 18, 2007 | 03:08 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by uzun
The reason I ask is because I have some BMW coolant remaining from my previous BMW and I would hate to throw it away. Can I safely use it in my MINI...
It's the same. It should be blue in color.
Rich
Old Apr 5, 2008 | 02:09 PM
shokk's Avatar
shokk
7th Gear
What are the specs for the coolant? I looked in the owner's manual, and it says check with the Mini dealer. Where do I get the blue coolant and what do I look for? Need to pick this up today.
Old Apr 5, 2008 | 02:13 PM
dajiggalo's Avatar
dajiggalo
I can understand being **** about the specific type of motor oil to put in our cars.... but does the brand of coolant really matter?
Old Apr 5, 2008 | 04:04 PM
uzun's Avatar
uzun
I just checked the container of my BMW coolant (which is the same as MINI coolant) and it says this coolant is ethylene glycol based and contains no nitrites or phosphates. This coolant apparently prevents the formation of harmful deposits.
Old Apr 6, 2008 | 09:18 AM
johne123's Avatar
johne123
Yes. Mixing some that are incompatible can leave to them solidifying. Even if draining all of one type some will always remain in the block. So even switching from one to another isn't a straight forward procedure.
Old Apr 6, 2008 | 10:02 AM
djam43's Avatar
djam43
Previous posts have indicated that Zerex G09 is approved by bmw.
Old Apr 6, 2008 | 10:08 AM
miniclubman's Avatar
miniclubman
I would strongly recommend using the MINI approved coolant. I believe that the coolant should be changed every four years, so it's not like the extra cost is that big a deal. It should run about $20 / gallon, and it's full strength, not premixed, so it will make 2 gallons of coolant when mixed 50/50 with distilled water. Use only distilled water, less than $1 a gallon at WalMart.
Cereall
Sep 5, 2019 06:05 PM
theateist
Jul 2, 2017 02:21 PM
kwijmbo
Aug 5, 2015 09:00 PM
