R56 Transmission Fluid Break-In Change
Old Oct 29, 2007 | 06:11 PM
  #26
r56mini's Avatar
r56mini
It is not difficult to change out the manual tranny fluid. There is one drain plug and one fill plug. http://www.lonestarminiclub.com/foru...read.php?t=474
That's for 1 gen MINI but similar.
Oil is cheap at less than 2 quarts probably. You should change the oil as often as you like. I usually change mine yearly.
Edit: I have a pump that attach to the oil bottle.
Old Oct 29, 2007 | 06:17 PM
  #27
ScottinBend's Avatar
ScottinBend
You really need to check with the service folks.......many have had problems using something other than stock fluid. And the stock fluid is a long life product like the Amsoil tranny fluid was.
Old Oct 29, 2007 | 06:18 PM
  #28
Crashton's Avatar
Crashton
Yep easy & cheap.
Tip***** Remove FILL plug first. If you drain & can't get the fill plug out you are so screwed.
Old Oct 29, 2007 | 06:19 PM
  #29
Crashton's Avatar
Crashton
I agree Scott. What you put in should be compatible with what MINI recommends. If you have a factory installed LSD, I would use MINI's fluid.
Old Oct 29, 2007 | 07:12 PM
  #30
r56mini's Avatar
r56mini
Does the differential in FWD use the fluid that is in the transmission?
Old Oct 30, 2007 | 05:16 AM
  #31
smackboy1's Avatar
smackboy1
I believe the differential sits inside the transmission. So yes, it's all the same gear oil. Here's a question, if the car has an LSD, is a friction modifier required to be added to the gear oil?
Old Oct 30, 2007 | 01:31 PM
  #32
Crashton's Avatar
Crashton
On most cars yes. That includes the MINI.
I do not know if a friction modifier is used. It's a clutch type or rather a cone type. I'd think that the fluid used in a non LSD equipped car would be different.
Old Nov 12, 2007 | 02:12 AM
  #33
OrionLTD's Avatar
OrionLTD
OK so I am scratching my head. I cannot locate a dipstick for the Auto Trans on my 07 MC. I found the rather hard to read oil one but no tranny. Is it just a sealed system that gets its 90K service? Is there a way to check fluid level?
Old Nov 12, 2007 | 09:53 AM
  #34
r56mini's Avatar
r56mini
No dipstick in 21st C. BMW's. Auto tranny fluid is probably temp sensitive. Not as simple as Manual tranny fluid change.
Old Nov 12, 2007 | 10:24 AM
  #35
going4speed's Avatar
going4speed
plus one
Originally Posted by Crashton
Wow, back on topic.
For my 06 MCS 6 speed. They say lifetime fluid. I respectfully disagree with that. No way no how for my car.
Old Nov 12, 2007 | 05:11 PM
  #36
Farmer-Ted's Avatar
Farmer-Ted
If yor car has a LSD I would diffinately change the trans fluid. As the clutches in the LSD wear the particles have go somewhere (in the oil).
Old Nov 12, 2007 | 05:27 PM
  #37
Crashton's Avatar
Crashton
Yes I am very surprised that MINI would call the diff fluid in an LSD equippped tranny lifetime.
Old Nov 12, 2007 | 05:31 PM
  #38
Robin Casady's Avatar
Robin Casady
So, when should it be changed?
Old Nov 12, 2007 | 05:41 PM
  #39
Crashton's Avatar
Crashton
Well for me it's at 30,000 miles. Non scientific, just what feels right to me. 2 quarts of lube is pretty cheap insurance.
Old Nov 12, 2007 | 08:53 PM
  #40
Farmer-Ted's Avatar
Farmer-Ted
For me, it would probably be every two years regardless of mileage.
Old Nov 12, 2007 | 11:01 PM
  #41
Robin Casady
Thanks.
sprp85
Aug 22, 2015 06:16 AM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
FLYM1N1
Aug 16, 2015 01:17 PM
