R56 Tire Pressure for R105 18 inch?
Old Oct 14, 2007 | 04:17 AM
VinceG's Avatar
VinceG
I was reading the manual and the side of the drivers door panel and was stating that the 18 inch tire should be inflated to to 38 pds. I checked my tires and they only had 32 pds. Filled them up to 38 and now the ride really is very harsh. For measuring purposes I waited till the tires were cold before taking readings and filling up with air. The 32 pds seems to be the better pressure, what do you folks think. Thanks!
Old Oct 14, 2007 | 08:12 AM
SLOTKAR's Avatar
SLOTKAR
I also found 38 a little harsh (with JCW suspension). I typically had 35-36psi and got 28K miles out of the set; much longer than most owners report. Rotated every 3K miles and wear was even to the day I chenged tires.
Old Oct 14, 2007 | 09:13 AM
spam052's Avatar
spam052
is 29 psi to little for a set of 17??
Old Oct 14, 2007 | 02:48 PM
ghosthound's Avatar
ghosthound
lower tire pressure is definitely going to have a softer ride. With a 18 inch wheel, you probably want to run a higher pressure because your side profile is so low you dont want to damage your rim if you go over a bump.
Old Oct 14, 2007 | 05:55 PM
going4speed's Avatar
going4speed
Too hard
38 is too hard if you ask me. Once the tire heats up it will be probably close to 44.
35 should much better although on my current car with 17's I run 32.
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
