R56 Adjusting Headlights
Old Oct 5, 2007 | 09:56 PM
jw34's Avatar
jw34
Adjusting Non-Xenon Headlights
Can non-Xenon headlights be adjusted? I think mine seem to be throwing a little low and I wondered if I can adjust them up a pinch.
Old Oct 6, 2007 | 02:56 AM
Krut's Avatar
Krut
Yes they can - see this post. Don't forget we have a search engine on NAM - it helps avoid duplicate posts and often times you can find the answer you were looking for.
Old Oct 6, 2007 | 05:47 AM
lacning74's Avatar
lacning74
The link refers to Xenon headlights. I also want to adjust my standard non-Xenon, Halogen headlights, but I've only seen specific info on adjusting Xenons.
Originally Posted by FLKeith
I wish adjusting the non-Xenons was as easy as using a screwdriver. It seems you have to loosen four bolts on each lamp which makes the whole assembly floppy, adjust spacer bolts, tighten it up and see what it looks like. This makes small adjustments very difficult. Is there a better way to do this?
I hope it's easier than this.
Old Oct 6, 2007 | 06:26 AM
jw34's Avatar
jw34
Yes thank you. All I found talked about adjusting Xenons.
Old Oct 10, 2007 | 05:41 PM
jw34's Avatar
jw34
In case anyone has an issue with non-Xenon headlights, yes they can be adjusted. My dealer raised mine a little and it makes a world of difference.
Old Oct 11, 2007 | 12:18 PM
lacning74's Avatar
lacning74
Great. Next time I take my car in to the dealer, I'm raising mine. Do they use some standard calibration, or did they just arbitralily raise it "a little"?
Old Oct 11, 2007 | 05:33 PM
FLKeith's Avatar
FLKeith
After messting around (as described above) I was pointed to the white plastic screws at the back inside edge of the lights to adjust the height.
Adjusting is easy - park on a flat road facing a wall. Cover one light with a towel and turn on high beams. Measure the height of the center of the headlight and adjust the beam until the center of the brightest point on the wall is at the same height. Move the towel over and adjust the other side and then road test.
Kevdog
Electrical
17
Jun 4, 2016 02:20 PM
Vaderm34
Sep 27, 2015 09:25 PM
Burkee52
Electrical
Sep 18, 2015 11:12 AM
tylewis
Sep 6, 2015 07:36 PM
Ntety
Sep 2, 2015 08:39 PM
