R56 Programming
Yup - 2007 R56 MCS with auto climate, power fold mirrors, bluetooth, premium, sport package, etc. Ordered in June 2007, built in August (so I'm told) and picked up last week.
I'm in Toronto, Canada. The dealership is one of the biggest in the country - BMW Toronto. They're usually quite knowlegeable about these things, or at least they have been in the past with other cars (including our previous MINI).
I've spoken to the service manager and called ASK-MINI, both to no avail. The manual doesn't have any instructions about this functionality. If someone has some instructions from their manual, I'd love to see them!
As far as I know, the differences between US and Can cars are the km/h speedometer and daytime running lights. The packages are also slightly different. Oh, and Canadian cars seem to be far more expensive!
Is this in relation to programming all options or the one touch sunroof?
The US spec manual is available on motoringfile.com and has the instructions for the daytime running lights, remote door unlock, etc, etc.
Thanks for the reference, here's the manual:
https://ol.miniusa.com/publications/...NI_Hardtop.pdf
Here's what it states (no one-touch):
With the glass sunroof raised, press the switch back as far as the pressure point and hold it there. The front glass sunroof opens. The rear glass sunroof is closed. Releasing the switch stops the movement. The glass sunroof can be closed in the same way
With the ignition switched on, press the switch back beyond the pressure point. Both closed sunroofs are automatically raised.
Opening, closing
By comparisson, the 2002 MC/MCS Manual states:
Automatic opening
Push the switch back past the point of resistance: The sunroof opens completely. Touching the switch briefly during opening stops the movement immediately.
I dunt(tm) care what anyone says. Romi is not programmable. I have probably burned at least one tank of gas idling just trying to change any option at all. It ain't happening. It does not do what it says in the manual at all.
Everyone on NAM tried to help, but to no avale. It just aint gonna happen.
Fortunately, it aint a big deal to me. The default configuration is good enough.
Huh, why were you idling at all trying to program your MINI? It's supposed to be done with the engine off. Just press the start button without stepping on the brake, might need to hold it a bit, till the car comes on. Course, you do have your key fob inserted. Not going to work without it. Then you can start programming your car.
Um, my MA said the engine had to be on to program some stuff, and I found this to be so. I *think* it even says this in the manual.
I did the 3 blink, unlock on one side only, no daytime running lights, and some other stuff I can't remember.
I have comfort access. Not even sure the fob will fit in the slot. Of course, maybe it will and maybe that I do have to do that. Not sure. The manual is not clear on that.
I cannot recall if I ever tried putting the fob into the slot. If that is the case, I will skip trying to program her. Last time I drove a Mini with the fob inserted in it, it had to go to the dealer to get it removed.
Me too... I've tried until I was blue in the face but it just doesn't work for me either (week 34 build). I have to use the actual key (not the key fob) in order to get comfort open/close to work at all. Bummer!
For those who dont know how to
For 07 R56 this is how you use the convenient opening from the FOB and using the Key
Hold the unlock button down on the Key Fob.
The power windows are opened and the glass
sunroof* is raised.
You must hold it the button down the whole time or it stops
Convenient closing is not possible by
means of the remote control.
Using your key you turn to unlock and hold it in the turned position (to the left), everything starts to open and you must hold it in the unlocking position until everything is open or it stops in the middle of it. To close everything you turn your key to the lock position (to the right) on the door until everything is closed.
sunroof* is raised.
Actually, the Owner's Manual clearly states that for those with the Convenient Access feature, the comfort open AND close option works by simply holding down the (little black) button on the door handle.
However, I can't get it to work like that. Also, it doesn't work by holding down the button on my key fob either. The ONLY way I've been able to get it to work thus far is via the actual key being placed into the door handle (both open and close work just fine that way for me).
Both the key fob button and door handle buttons work on Skeeter.
It's not just you. I have build week 34 too. C.A. open works from the fob. To close all windows, you must use they key-method. I'm going to mention this when I go in too. I'm guessing it's some liability thing (closing stuff when you can't actually see if someone is hanging their head out the sunroof, etc).
Navigation & Audio Installing the PAC SWI-RC Steering Wheel Control Interface
Filmy
Jun 28, 2016 08:58 AM
ARRRRRRRRRRRGGGHHHHH!!!!!!
