R56 removing hoodscoop problem midway....
Old May 5, 2007 | 03:10 PM
thlaxx's Avatar
thlaxx
ok i know there are several posts on this but in them the part where i am is not well described.
Once you remove the 2 visiable screws, remove the star screw under the plug, then your supposed to pop the block out....now which way are we popping and how, do you pull up from the outside of the hood and push the hoodscoop in towards the engine [pushing on top or bottom of block?], or do you push up on the inside and push scoop out towards the outside, do you pull up from out side while holding the block? bla bla bla....and which way does it pop so the other hidden screws are visiable.
any help would be lovely.
Old May 5, 2007 | 06:57 PM
thlaxx's Avatar
thlaxx
help...
Old May 5, 2007 | 07:06 PM
MIN 18's Avatar
MIN 18
what will you do when you pop out the hood scoop?
Old May 5, 2007 | 07:37 PM
thlaxx's Avatar
thlaxx
after that i will put in a new CAI with a KN rx4990. Gives it kinda of a supra sound, the phssst, and probably a few mor horses, no one has dynoed it yet, theres a thread on it under DRIVETRAIN if you want
Old May 6, 2007 | 12:06 AM
MIN 18's Avatar
MIN 18
Is this specifically designed for the MINI? I'm interested in changing my intake too.
Old May 6, 2007 | 10:00 AM
thlaxx's Avatar
thlaxx
no someone jsut thought of it, alta is making one now, go under 2nd generation, then under drivetrain, and its normally the first thread
Kimolaoha
Jul 5, 2023 01:04 PM
alistaircookie
Oct 8, 2015 10:52 AM
ltjpunk7
Sep 6, 2015 07:32 AM
Zettinger
Aug 25, 2015 04:04 PM
