R55 How To Replace Wiper Blade Inserts
Old Apr 18, 2021 | 07:49 AM
timfitz63's Avatar
timfitz63
Standard disclaimer: searched the site for this solution, did not find any relevant threads...
Somewhere along the line I got the impression that one could replace just the rubber blades on the wipers instead of the entire wiper blade assembly (i.e., the blade with the supporting arm framework); in fact, MINI/BMW offers what they call "wiper blade inserts," which appear to be just the rubber blade, and a set of which costs roughly 2/3 the price of a pair of wiper arm assemblies (which, given the "BMW tax" on these simple maintenance items, means a lot of folks might just opt to avoid the fuss of changing the inserts and replace the whole assembly...). But nowhere can I find the "how to" that explains the swap out procedure for a wiper insert. I'm guessing the inserts just slide in/out of the wiper arm frame, but I'm seeking a little clarification/confirmation about the whole concept:
  1. The front blade inserts come in one size: 475mm; which apparently means an insert needs to be cut to fit the driver's side blade frame (which is about 450 mm). Simple enough.
  2. When installed, the blades have a thin, flexible metal strip that runs along its length; the strip appears to serve two purposes: to provide some structural rigidity to the rubber blade insert, as well as a little spring tension to hold it against the curvature of the windshield as the blades sweep; and to lock it into the wiper arm frame. The question here is how to release the blade/metal strip combination from the wiper arm frame without breaking/bending the small clamping tabs that hold it? The wiper blade inserts appear to come with some kind of small 'tool' that may aid in this; but none of the online parts sellers elaborate on this 'tool.' I'm also presuming that one just re-uses the metal strips?
So can someone set me straight on the mysteries surrounding wiper blade inserts...? Thanks!
Old Apr 18, 2021 | 08:14 AM
Yoshimura 1's Avatar
Yoshimura 1
I used a needle nose to squeeze it together and remove it. I also start at one end and push it to the farthest end giving a little wiggle room
then pull it out.
RandomGemini
May 10, 2009 04:28 PM
dubsdj
Mar 4, 2008 07:41 PM
herbie hind
Jan 13, 2008 07:55 AM
parzifal
15
Sep 1, 2006 12:30 PM
holdenontoit
Jan 7, 2006 08:37 AM
